Motor problem-d15b
Old Jul 20, 2010 | 09:33 AM
Banner's Avatar
Default Motor problem-d15b
Okay, I was driving the car one day and everything was fine. Came home and parked it.
The next day I went to start it and it would turn over but not start. I tried to jump it with my s2000 and it didnt go. So...I took spare spark plugs out of my other motor out, and replaced my old spark plugs. The car sputtered and started.
While it was running, I would rev the motor and it would bog and die on the way down from the revs. The motor was smoking from the exhaust a little bit, but I figured it was from burning the gas from the previous attempts to start up.
I went to start it up again today because I went out of town, and the car will not start once again but will turn over.
Any ideas? Please help me its my dd. Thanks guys.
Old Jul 20, 2010 | 09:47 AM
delsolproblems's Avatar
Default Re: Motor problem-d15b
First check your grounds. The best way IMO is with a meter set to resistance. Stick the black probe in the battery negative post and touch the red to cleaned bare metal that a ground strap is connected to; the valve cover for example. No resistance is a good connection. You can do a cheap check on your fuel system by priming the engine a few times before trying to start it. Turn the key to on so you hear the pump turn on, turn the key back to off and repeat 3 times and then crank it. If this helps and the filter hasn't been replaced in awhile, get a new fuel filter. If none of these checks find the problem, come back and we'll test the ignition.
Old Jul 20, 2010 | 09:57 AM
nothing_shocking's Avatar
Assuming it's the JDM D15, what car is it in and what ecu are you using?
Old Jul 20, 2010 | 10:08 AM
Boosted EJ2's Avatar
A similar problem happened to myself as well as a buddy of mine. For both of us it turned out to be the ignition igniter in the dizzy was bad.
Old Jul 20, 2010 | 10:35 AM
Former User's Avatar
Originally Posted by delsolproblems
Turn the key to on so you hear the pump turn on.
In addition for listening for the fuel pump priming, also check for spark at all four plugs. Spark should be bright white.
Old Jul 20, 2010 | 11:47 AM
Banner's Avatar
Thanks guys, Im going to check all of these now. I appreciate it and will update.
Old Jul 25, 2010 | 02:13 PM
Banner's Avatar
Checked spark plugs and replaced fuel filter, still no go. Going to try dizzy next i guess? Fml...
Old Jul 25, 2010 | 02:18 PM
Did you do this^^?
Replacing parts at random will become expensive very quickly and will not ensure a fix. You must do some troubleshooting.
Old Jul 25, 2010 | 02:23 PM
Banner's Avatar
Yeah I did that, thats why I replaced the parts I did from my troubleshooting.
Old Jul 25, 2010 | 02:24 PM
Banner's Avatar
And I replaced the plugs just because they needed replaced soon :p
But the filter was because I can hear the fuel pump.
Old Jul 25, 2010 | 02:28 PM
So there is bright white spark at all four plugs and the fuel pump primes, right?
If so, are there any CEL codes? Have you checked the mechanical timing?
Old Jul 25, 2010 | 03:22 PM
Banner's Avatar
Havent checked timing.
No cels and yes on the plugs and pump.
Old Aug 12, 2010 | 11:54 AM
Banner's Avatar
Went on a vacation so I didnt get to mess with it.
Replaced the igniter module, no dice.
Old Aug 12, 2010 | 12:00 PM
If you had good spark, then there was no need to replace the ICM.
Old Aug 12, 2010 | 12:13 PM
Banner's Avatar
I have not checked that. Its hard for me to get at the car since its still at my old place of living.
Old Aug 12, 2010 | 12:16 PM
HondaPartsHero's Avatar
Technical Hero
start here if you find you don't have spark:
http://techauto.awardspace.com/ignition.html
http://techauto.awardspace.com/mainrelay.html
Old Aug 12, 2010 | 12:19 PM
Seriously, if you have time to replace parts at random, then you have time to do some basic troubleshooting.
-Check for spark
-Check whether the fuel pump primes
-Check for CEL codes
-Check the mechanical timing
ef9_pr0jekt
Mar 7, 2020 07:44 AM
dkillahster
Sep 10, 2010 12:26 PM
w0ng_sta
Jan 31, 2007 12:41 PM
chumpman
May 14, 2005 09:46 PM
WhiteTegSE
May 3, 2004 09:20 PM
