97 GSR in my 95 hatchback DX..Wiring harness??
im dropin a 97 GSR into my 95 eg6 dx and i dont want the restrictions of the ob2 ecu so i wanna use a ob1 ecu and i know they make custom harnesses but im not to sure where to look at to get one...i dont want any jumpers though im tryin to find the plug in play ones...any help would be appreciated!
Well your gonna have to wire up vtec solenoid and pressure switch, knock sensor and intake air bypass (iab). Even if you found a gsr engine harness you have to wire up all of the above Or if your lucky enough to find a gsr obd 1 harness that connects to the engine harness to the ecu you'll be straight. Gl
yea, im just lookin for a harness already made like rywire who makes costom harnesses but i only see there hi end race harness which is $550 (mil-spec), so if anyone knows another company who makes them but arent as pricey plz let me know!
You are going to need VTEC, knock and IAB wiring plus an O2 extension harness from the DX location to the GSR's location. check my sig if you have any questions pm me
lots of good info here.
http://www.ff-squad.com/technet/hybrid.92-95.obd2.htm
you need to get an obd2 integra engine harness for this swap. and as others have said, wiring in vtec, knock, iab
ColinSiR
May 11, 2008 12:19 PM
EG civic
May 29, 2006 08:15 PM
Mugen112
Jul 12, 2005 09:25 AM
