quick help please?
Old Jul 19, 2010 | 05:42 PM
-=ZAK=-'s Avatar
Default quick help please?
have a 93 civic hatch. has a ls from my integra in it obd1. it ran in the integra. wont in the civic. fuel pum p primes, dizzy and ecu are good tested on another car and ran fine. what could be wrong? pulled injectors and theye are spraying. fuel pump has hella pressure. can hear and feel main relay clicking. all fuses are good, battery at 100% turns over fine but just wont crank, pulled plugs and dizzy isnt firing.
Old Jul 19, 2010 | 05:47 PM
Fzn14's Avatar
Default Re: quick help please?
If your Dizzy is not getting spark...you could get out a volt meter to make sure its even getting voltage...and then if not it could be an ecu issue....just a thought
Old Jul 19, 2010 | 05:53 PM
Former User's Avatar
Any CEL codes?
Also test the coil and igniter unit inside the distributor and make sure the timing belt did not snap or strip.
Old Jul 19, 2010 | 07:01 PM
-=ZAK=-'s Avatar
dizzy is getting power according to my test light, ecu is fine worked in other car, pr4 ecu has cel code, single cam ecu dont have code. the timing belt is a month old i put it on when the motor was in my teg, running and driving. tried putting another dizzy on that i know 100% works because my friend drove to the house using it, but the same problem.
Old Jul 19, 2010 | 07:32 PM
What codes are thrown by the pr4 ECU?
Old Jul 19, 2010 | 07:41 PM
-=ZAK=-'s Avatar
ill have to post them tomorrow.
Old Jul 20, 2010 | 07:57 AM
-=ZAK=-'s Avatar
well i tried to pull ecu codes, and it wont let me, i hooked the double pin together and turned the key but the cel just stays on, no flash.. iv been looking at obd1 pin outs all day to see if anything in my harness has been hacked but it all looks good. as i said inknow the dizzy and ecu are good, so what else could be causing this?? still not firing but turns over like a charm?? im confuuuuuuuuused.
Old Jul 20, 2010 | 08:02 AM
With the PR4 installed, does the CEL remain on steady when the key is turned to ON(II) without the service connector jumped? If not, crank the engine for about 30 seconds and then check again. When the CEL remains on steady, jump the service connector immediately.
Old Jul 20, 2010 | 08:03 AM
-=ZAK=-'s Avatar
haha it wont crank bro, not firing
Old Jul 20, 2010 | 08:05 AM
The starter does not crank the engine? I thought the starter cranks but the engine does not fire up and run.
Old Jul 20, 2010 | 08:09 AM
-=ZAK=-'s Avatar
my bad haha, i thought you ment start the motor o_0 i dumb sometimes. give me a second ill go try
Old Jul 20, 2010 | 08:15 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Long shot but is the ground wire at the thermostat housing present, and tight?
Usually it will disable the fuel pump, but possibly it could be affecting spark delivery.
Old Jul 20, 2010 | 08:45 AM
-=ZAK=-'s Avatar
got power to the dizzy, but now my fuel pump dont have power. i can still feel the main relay clicking though?? yeah the housing ground is present and tight
Old Jul 20, 2010 | 08:48 AM
Check fuses 31, 24, and 18.
Old Jul 20, 2010 | 08:51 AM
-=ZAK=-'s Avatar
they are all good, my dad said to open the main relay and check the connections, he said if the have a halo around the solder then to redo it and it could help?
Old Jul 20, 2010 | 09:03 AM
-=ZAK=-'s Avatar
AHAAA! my main relay isnt getting power to the #7 pin. from intense seconds of typing on google i have come to the conclusion that the nuymber 7 pin goes to fuel pump.
Old Jul 20, 2010 | 09:16 AM
-=ZAK=-'s Avatar
all this leads to my next question. which main relays will work in a 93 eg civic? i have a rz-0088 but its out of an accord and i think its obd2
Old Jul 20, 2010 | 10:22 AM
Resolder the main relay and check the three fuses with a voltmeter.
eg6_vti93
Oct 30, 2012 12:31 PM
turboef90
Jun 19, 2012 01:45 PM
DA_9
Mar 11, 2008 03:17 PM
mstealth22
Jun 4, 2004 10:05 AM
ocbeta
Jul 5, 2002 03:37 PM
