Piston removal Help!?
Old Jul 19, 2010 | 08:06 AM
kUrb3d's Avatar
Default Piston removal Help!?
Hey guys, have run into a grey area with removing my pistons(engine in car)
I have everything removed from the block(top and bottom) oil pan is off. Question is, do I remove the large bracket(10 Bolts) that sits up against the crank, or do I just remove the rod endcaps with this brace in...I am going to push the pistons up through the top of the engine, just don't want to break any seals on the Crank unless I have to...Hope someone can help me out, thanks.
Old Jul 19, 2010 | 09:28 AM
rickkane's Avatar
Default Re: Piston removal Help!?
By large bracket do you mean the windage tray? You should remove it, unless you can get to the rod bolts easily, then I guess you don't have to. Are you not taking the crank out? Why are taking out the pistons and leaving in the crank?
Old Jul 19, 2010 | 09:31 AM
D16SiHatch's Avatar
you're doing it with the engine still in the car?
that sounds like fun
Old Jul 19, 2010 | 10:02 AM
Adamvanxxx's Avatar
Yea I would recommend removing the engine, it will make your life so much easier.
Old Jul 19, 2010 | 10:46 AM
kUrb3d's Avatar
By Large Bracket I mean main bearing cap, can I take this off without the crank dropping out, or do I have to work around it to get at the rod end cap? Unfortunately taking the engine out is not an option for me...wish it was, just replacing pistons/rings and rod bearings...I know it can be done with the crank left in, just want to know if I take off the main bearing cap, will the crank drop? or any crank seals ruined?
Life isn't always easy...lol
Old Jul 19, 2010 | 11:20 AM
98y8's Avatar
You should be able to remove the pistons with the windage tray I also suggest cutting a section of hose to put over the rod bolts so you don't scratch up the cylinder walls.
Old Jul 19, 2010 | 11:27 AM
kUrb3d's Avatar
thx 98Y8, will give it a go...If I do remove the windage will I have to replace any seals or bearings, in case things don't go so smooth...
Old Jul 19, 2010 | 11:29 AM
98y8's Avatar
No its just a couple of 10mm bolts
Old Jul 19, 2010 | 12:34 PM
D16SiHatch's Avatar
well yes, i certainly wouldn't pull the tray/crank and not replace the main bearings.
Old Jul 20, 2010 | 05:07 AM
kUrb3d's Avatar
Perfect thanx, got the pistons out without removing the Main Bearing Bridge...wasn't that bad. Honed the cylinders last night, gotta drop off the piston/rods to have the new pistons pressed with the new bearings to the rods. Just gotta get that engine clean on the inside and lube it up, so I can start putting it back together. Thanks for the help, will probably be back asking more questions soon.
Old Jul 20, 2010 | 05:24 AM
Boosted EJ2's Avatar
As long as you can reach the bearing cap bolts you dont HAVE to take the tray off. I would recommend taking it off though and getting new gaskets for the bottom end. Might as well since you took that much apart. Unless you are trying to keep it to a small budget.
Old Jul 22, 2010 | 05:30 AM
kUrb3d's Avatar
Finally finished the pistons. It wasn't too much of a problem, left the crank in, honed the cylinders, washed them out, oiled the crap out of everything, then installed the new rod bearings and pistons. Hope my Z6 head goes on that easy...
Old Jul 22, 2010 | 08:18 AM
newtron63h's Avatar
you used warm soapy water to wash the cylinders right? solvent will keep grit in the newly honed cylinder walls.
Old Aug 4, 2010 | 02:27 PM
kUrb3d's Avatar
ya warm soapy water in a spray bottle, took a while before I didn't get any grit on an oily rag...bottom end moves like butter now...
Old Aug 5, 2010 | 05:37 AM
newtron63h's Avatar
nice
Old Aug 5, 2010 | 08:03 AM
EF9_TryMe's Avatar
sweet. learned something new.
Old Aug 29, 2010 | 11:35 AM
hondanick's Avatar
Hey im kinda doin this project too, I burnt a valve in my honda so i have the head off going to get machined and it has 147k miles, do you guys know what the odds would be for blow by after i get everything reinstalled? I wanna just do the rings and pistons but i've never dipped my hands in that area before, after reading this post it sounds pretty easy my only question is and bear witih me here haha, why do you have to press the pistons? and how did you hone the cylinders yourself? is there no specific spec you have to hone them too
Old Dec 23, 2019 | 08:43 PM
Chris T.'s Avatar
Honing the cylinder is done to break the polished surface so the new piston rings can seat and seal properly. The cylinder spec is to keep the piston moving freely without too much play. Before deciding to replace the pistons, you should measure the cylinder wear. At a certain point (check the specs for your engine) you will need to have the block machined and install oversized pistons. The cylinder wear can be measured without further disassembly by rotating the crank until about 2 inches of the cylinder are exposed. This is where the most wear will be.
Old Dec 25, 2019 | 05:02 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
The thread is from 2010. Your response is 9 years late.
eH.
Old Dec 26, 2019 | 02:23 AM
Malt-liquor's Avatar
I had this problem too, I used a crow bar wrapped in a shirt and tapped it with a rubber mallet. Eventually it broke loose.
Old Dec 26, 2019 | 04:57 AM
Chris T.'s Avatar
eH.
LOL! Better late than never?!?!
managon_5
Mar 23, 2009 08:07 PM
tei344
Sep 19, 2007 02:29 PM
boomersz
10
Apr 11, 2007 11:48 AM
eMpAtHy
Jul 13, 2005 07:46 AM
thinkbrianthink bu
May 7, 2002 09:14 AM
