turbo issues Would like some opinions
Old Jul 17, 2010 | 06:16 PM
brent_si's Avatar
Default turbo issues Would like some opinions
I have a turbo b16 with built bottom end. And it smokes blue a little bit. But the motor was built by bischoff racing engines and only has 12k miles on it. And just got brand new garrett 60 trim turbo on it. Was wondering if the wrong size oil feed/return could cause it to smoke like that?
Old Jul 17, 2010 | 08:05 PM
bigD's Avatar
Default Re: turbo issues Would like some opinions
yes it can
Old Jul 17, 2010 | 08:24 PM
EsotericImage's Avatar
Retired Moderator
If your using anything over a -3 you should run a restricter. you might have blown the seals. check pipe and see if theres oil in it.
Old Jul 18, 2010 | 01:25 PM
motoxman's Avatar
I agree with Esotericimage... Runn a restrictor in your oil feed and use as large of a drain as you can taking care to make sure that there are no kinks or low spots in the drain hose... if possible using a 45 degree bung on the pan pointing up with a more direct route to your tubo will be better... Any oil back pressure from teh drain could cause the seals to blow just as too much oil pressure to the turbo can...
4tika4
Mar 28, 2012 04:41 AM
Bigrederic
Apr 29, 2010 06:18 AM
b00stedbyFastrax
Nov 29, 2005 02:54 PM
GruvyTune
Nov 18, 2001 05:46 PM
