Ignition switch part # for EG?
Called up my local honda dealership looking for a ignition switch for my 93 civic cx. They had stated the electric switch harness is not sold separtely from the lock assembly?. I went online and couldn't find a part number either. Can anyone verify the part number of the electrical switch harness?
Take a pic of what you need. I have a column in my garage, PM me with what you need, I may have it. If it's the wire thing on the back of the ignition switch, I'm pretty sure I have one.
If you can, look around and see if you can get a column off a EX, LX or another model with a tilt column, that is if you would want one.
Yes it does have a two plug harness connected under the dash to the fuse box. I rather just buy a new one. Thanks for the offer though
LOCK ASSY., STEERING
35100-SR3-A02
35100-SR3-A03
Some parts stores can cross reference OE part numbers. These are the OE part numbers.
Autozone cross references to the part number LS880. Unfortunately it looks like locally that part lists for about $230.
35100-SR3-A02
35100-SR3-A03
Thank you, So the ignition switch is not sold separately from the lock assembly?
allenhogans
Jul 26, 2017 05:20 AM
