What tranny do i have?
Old Jul 17, 2010 | 10:49 AM
eghatchfla's Avatar
Default What tranny do i have?
I have a b18b1 in my eg hatch.. i bought the motor and the guy said it was a b16 tranny. Is there a code or something on the tranny? if so, where is it located??
thanks
Old Jul 17, 2010 | 10:52 AM
93EssEYE's Avatar
Default Re: What tranny do i have?
on d series trannies, theres a series of numbers and letters cast into the tranny above the fill plug. Im not sure about b series but i dont see why not, if no one verifies i can go look at our torn up ls tranny in the shed..you would also have to look up the numbers for each tranny online..or im sure theres a post on this site.
Old Jul 17, 2010 | 02:23 PM
Targa250R's Avatar
be professional
Look for a VIN tag, and/or for the 3-character transmission code on the serial number sticker. The information in this PDF is fairly accurate: http://www.jdmcars.com/tech/admin/bseries_tranny.pdf
Since most hydraulic-clutch B18 transmissions used the same code, they're very difficult to distinguish without opening them up to count teeth (unless the VIN tag is still attached in the case of later model years). B16 transmissions had different codes from the B18 models IIRC.
One thing that they don't note is that the S4C transmission code was also used for the '99-00 Civic Si non-LSD B16A transmission in addition to the LSD B16B transmission.
Old Jul 17, 2010 | 03:10 PM
eghatchfla's Avatar
okay thanks alot guys!
Old Jul 17, 2010 | 03:28 PM
r.etheridge's Avatar
unless its a jdm then your screwed, atleast I was for my B16
Old Jul 18, 2010 | 06:19 AM
300whpej's Avatar
Here's a pretty easy way to tell:
-Find a stretch of highway where you can get up to 80mph safely
-Once at 80 mph look at your tach
-If your tach is reading around 3200k your transmission is from a LS, if your tach is sitting at 4k then GSR, 4500 then B16, higher than 4800 ITR. This is assuming you have a factory transmission, not some freak trans with mfactory (or similar) gears.
Old Jul 18, 2010 | 07:20 AM
goldpearleg6's Avatar
make sure your in 5th gear when you test this way
Old Jul 18, 2010 | 07:43 AM
300whpej's Avatar
^True, forgot that little golden nugget.
Old Jul 18, 2010 | 08:20 AM
TCE_4BangN's Avatar
that isn't a very accurate way to find out. I have an LS trans out of a 96 DC. And I hover around 4K at 80 MPH. Reason I know what trans I have is because my trans has the vin tag on it. and its from an LS.
Old Jul 18, 2010 | 08:28 AM
300whpej's Avatar
I've ridden/rode (ridden sounds odd) in plenty of dc integra's and ls swapped cars and they have all been between 2800-3300 rpms, that is what I'm basing my post off of, however I haven't been in a car with an ITR trans/swap.
Old Jul 18, 2010 | 11:46 AM
eghatchfla's Avatar
yeah i would do that, but i have no 5th gear ):
so at 60mph im at 4k lol
Rash Ej1 SiR
Aug 28, 2006 03:39 PM
Da9teggy92
Dec 14, 2005 05:53 PM
ALL B SERIES
Aug 23, 2005 08:27 AM
arielmalespin
May 29, 2005 05:44 AM
HondaCutter
Aug 17, 2002 08:30 PM
