b20 swap wiring problems and other issues
whats up ht. i got a few questions, first of all my swap is a b20b into a 97 ek hatch. i finally got everything put together and i just have a few questions b4 to be on the safe side.
first what exactly do i have to do to get my iac all set, im usin the stock dx wiring harness so i believe i have the 3 wire plug and i need the 2 wire plug, i do have the conversion harness so i can run my odb1 p75. whats the best method to wire that up correctly.
second i was readin something about the crank sensor. i know its not near the crank pulley on my motor cuz it jdm. but what exactly ( if anything) do i have to do to make sure thats allset.
third i have basically the same problem with the iat as i have with the iac, what exactly do i have to do to hook that up. i have the skunk2 im with the iat sensor mounted on the runners but no plug on my harness that fits it.
thats basically it but if any1 could please help me out it would be greatly appreciated. i know some of this **** is pretty basic but i just want to make sure i do everything 100% correct and the right way the first time.
o and if any1 else has done a similar swap and ran into any other problems that i should look out for please feel free to warn me.
Maybe you should swap to a LS harness, that way everything will plug up with no wiring. Thats what I did for my car and I had no issues. When I originally did my swap, it was like replacing my motor with another stocker, cuz I used a harness from a 95 LS teg. Might be ur best bet as well to swap to a odbcorrect LS harness
well im so far along with this harness and ive already started the car, im kinda desperate to get in runnin so swppin out the harness now plus buyin 1 would kinda suck. any1 else got some info please
o i just realized when i was lookin at this site...http://www.b20vtec.com/forums/genera...u-pinouts.html... how do i repin it if im runnin a conversion harness with an obd1 ls ecu (p75). does any1 know?
my b20b dropped in my 97 ek everything plugged in an im running a obd1 p75 i bought the jumper harness to run it obd2 to obd1 an got the p75 basemap an delleted the sensor thats not neede
clearly im in idiot lol. its all set now so i started it up again and it was a little better but now i have another question. i start the car and it sounds like its got cams, its not idle surge, i have no vaccum leaks. but the car is breaking up down low. i took it for a quick drive down my driveway and when i put it in gear and try to give it gas it gets all chocked up and doesnt wanna go. heres the thing, i have a 66mm tb, intake and s2 intake mani, but i only have my header on as far as exhaust, could that be why are is there something else i should be looking for? i also dont have my 02 sensor in. could this be my problems or could it be something else??
i hate to be a past guys but help me out, just give me ur thoughts, my head is goin crazy tryin to figure it out, and i just keep thinking the worst
Bjm1118
Mar 12, 2019 04:58 AM
Wink1100
Feb 11, 2010 10:36 AM
backagainracer
Dec 24, 2006 03:59 PM
