Reffing a OBDII '99 GSR into OBDI EG
How tough would it be to do? I found a complete swap with engine, tranny, OBD2 to OBD1 harness and P72 ECU. I'm probably going to need a shift linkage and definitely motor mounts. I found a couple of threads that ended up dying with the question still unanswered. The asking price is basically what I'd pay for a low mileage LS and I don't want to pass this up. I just want to make sure I know what I'm getting myself into.
So if i get it, I want to work towards getting it CA BAR'd. My car is a '95 OBD1 Civic VX with a D15z1 and P07 ECU. The swap is a '99 GSR with about 110,000 miles with tranny, engine harness, obd2 to obd1 harness, and p72 ECU. Any help is much appreciated, thanks!
a obd2 gsr motor will drop right in a eg plug and play, just dropped one in like 2 days ago works perfect, plug and play
cliff note, the obd2 engine harness will plug and play to your obd1 car harness,
What else would I need exactly to make it it ref-able and smog? I want to make sure I know the job i'm getting myself into before i pick it up. Thanks, RHDCOUPE
to do a complete gsr swap, your going to need this stuff
gsr head
gsr block
gsr transmission
stock integra mounts or hasport b-series mounts
stock gsr axles
gsr halfshaft
p28 ecu
stock integra headers
what ever engine harness the engine comes with obd1 or obd2 will work plug n play
gsr torque mount on front of transmission
a/c mount to frame thats a ++ its nice to have
gsr head
gsr block
gsr transmission
stock gsr axles
gsr halfshaft
p28 ecu
gsr head
gsr block
gsr transmission
stock gsr axles
gsr halfshaft
p28 ecu
a/c mount to fram thats a ++ its nice to have
gsr head
gsr block
gsr transmission
stock gsr axles
gsr halfshaft
p28 ecu
hes right about everthing except you can use your EG mounts and the ecu just depends on the year of the swap the main thing is to make sure everything is connect to something and cant be throwing any codes i think that was the hardest part was getting the codes off the visual is a peice of cake to pass
the drive side mount on single cam the out put bolts on the mount bolted to the motor are angled a lil the b-series mount the out put bolts are str8... and the ecu you want to run a vtec ecu chipped p28 is good
p72 not a good option for ECU? Figured i'd use it since its coming with the swap, but didn't know p28 is a better option.
Thanks for the input so far.
You have to use the p72 to ref but ppl say p28 is a better ecu and I thought you could use your same mounts but that other dude is saying no. Just google it
The tranny mount will fit but the driver side mount u need to change it to any b series motor mount and the back one u need a t bracket for it to fit right I'n.. Also people forgot the Axels need to be b series and ecu if ur motor was not vtec u need to run a wire from ur ecu or harnest to the vtec selinoid if ur car is obd1 and ur gonna get obd2 the destrubuter and alternator are different u eather wire them up or just use the obd 1 alternator and obd1 injectors I'm not sure about this one but the obd1 don't have the crank sensor and obd2 does and that's a problem..
if your car is obd1 and you are running an obd1 ecu you will be fine for reffing it. it would just have to not be throwing a code and be running properly with a cat to pass smog
NO you can't use that motor for REF. Been there, done that. First hand experience. Law states that the motor going into your car has to be of the year or newer than the chassis it's going into. It also states that if it's from a newer OBD, you have to make your car that OBD.
I REF'd a 96 Hatch with a B16A2 complete swap. I had to swap EVERYTHING over from the donor car, when I say everything, I mean EVERYTHING: engine harness, dash harness, chassis harness, AND gas tank.
To answer your question, YES the motor will work in your car with the OBD2 harness no problem, you can run it on either a P28 or an OBD-1 P72, your choice. And, NO you won't be able to REF that motor in your car, not without major work at least. If you have any more questions regarding REF you can PM me or post on this thread, I currently own 2 REF'd cars, and have REF'd over 7 cars in the past.
Good luck.
EDIT: I barely noticed the date on this thread. Waste of time lol
Good luck.
^^^ damn I didnt notice that either
but either way I thought the op said the motor was going into an eg so the motor would be newer than the chassis
Yes the motor is newer than the chassis, he's ok that part, or was ok, who knows lol ... But the motor is also from a different OBD1 than that of the 92-95 Civics... As stated in my previous post, he would have to convert the car to OBD2
Good luck.
Good luck.
Pass visual/emissions = BAR'D. Simple.
Now, I've also heard the same thing from these white dudes from a local muffler shop. They said exactly what you're saying. I don't know if it's a "white" thing, but I call it BS.
Lol ^
But... I still have the GSR longblock in my garage and haven't gotten to work on the swap yet because it's my daily and I need to make sure I can get it BAR'D. Thanks for all of the feedback; I'm taking all of your opinions in consideration :]
No, negative. You don't have to swap "everything": dash harness, chassis harness, etc. If what you're saying is true then my friends couldn't pass on theirs. One of them passed his '97 hatch with a 99 B16a2 using a civic ex harness and obd2a P30 ecu. Another example, my other friend's '96 hatch passed with an obd2 B18B LS engine/tranny,ecu, no problems. They didn't have to do anything.
And for the record, I'm not white lol
Yes. You can get it bar'd. I'm in the process of reffing mines. I just need to fix some minor issues. Run obd1 gsr ecu and cat. w/o cel's and you should be good. Sorry for bumping old thread. To "slowhatchcali", you can only believe of what people say or hear 50% of the time and the other half you just have to experience it.
benson03
Dec 14, 2005 01:22 PM
saleensolution
Oct 25, 2005 04:42 PM
