Adding factory keyless remote. What is needed?
So, I've been working on my 98 hatch. I added the factory power windows and door locks. I got the floor harness from Honda and so far things are working. I want to know what else I need so I can use the factory keyless remote. Anyone know???
keyfob and factory stereo.
I think you need the radio for alarm and keyless since on 96-98 civic, the whole system is built into the radio while in 99-00 was separate or something. Can't remember correctly though
yeah.. its already converted to the 99-00 dash. But, I don't think there was anything in there that had to do with the power door locks.
'99 - '00 had a lock box in the driver's door.You can relocate the factory stereo either under the dash or in the trunk to have factory keyless, IIRC Metra makes a piggyback harness that takes most of the wiring out of the equation.
hmm so the factory keyless is in the sterio.. i wish mine was an 99-00 and an EX because i like the fact that when you unlock the car the turn signals flash haha my mom's Xb does that and i really like that. I have a DX
Correct '99 - '00 had a lock box in the driver's door.
Sorry i'm just a little confused too. If you don't have the factory stereo can you still have the factory keyless entry? And if so, how do you program the fob?
^. The lock box is what controls both doors. Like mine, I was tinkering with it; when the driver door would be stuck in lock, I'd hit the unlock button. The passen. side would unlock but not my door. When the door saw mine wouldn't open, it re locked the passen. door. In the 99-00, it seems everything is controlled from that box. So it seems you don't need to worry about your stereo.
96-98 Civics had the lock control box in the drivers door, if you don't believe me just check on www.hondapartsdeals.com and try to find it in a 99-00
99-00 it is located near the hood release inside the car.. but if you are running a DX and upgraded to power windows/locks from a 99-00 Civic.. well then good luck, since the dash harness doesn't contain the connector for the lock control box.. Believe me, I am currently at this stage.. all I have to do is remove the dash and swap the harness over to an Ex/Si and the lock control box will plug right in.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/99-00-civic-remote-entry-module-location-2284107/
2000si
Audio / Security / Video
Oct 23, 2005 06:16 PM
jbscivichb92
Nov 7, 2004 11:53 AM
