any issues if i block off egr valve?
Old Jul 16, 2010 | 07:11 AM
farfrumugen's Avatar
Default any issues if i block off egr valve?
i know this is a prelude forum, but i figured you guys would know this engine better than anyone.
im putting an obd1 jdm h22a into my 95 ex coupe. ill be running the stock p13 ecu.
instead of wiring in the egr if i just block it off will their be any drive ability issues with the car?
for example could it lose power or get sluggish on me?
i know ill get a code but that doesnt bother me as much as having more wiring to do ..lol just looking to see what problems if any i could have.
thanks
adam
Old Jul 16, 2010 | 08:34 AM
codyh's Avatar
formerly xmod_supra
Default Re: any issues if i block off egr valve?
Good question! I would like to know aswell.
Old Jul 16, 2010 | 09:23 AM
92civlude's Avatar
With a P13 ecu, youll get a code 12 and that nasty check engine light will be on all the time. To keep the light off, you could install a plate under the egr valve and wire the egr system correctly. Or, if you want to delete the vave entirely, run a P28 ecu with an H22 tune. The engine doesnt seem to run the same when the check engine light is on.
Old Jul 16, 2010 | 10:33 AM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
^ I don't believe the EGR CEL puts the car in limp mode or screws with the timing at all.
Worse gas mileage is a possibility.
Old Jul 17, 2010 | 04:56 AM
Apex1972's Avatar
dont know if it screws with the timing,but it does run like **** with a code 12. best to just hook it up correctly or run an ecu that can be tuned not to run with it. like hondata on a p72 would be good.
Old Jul 18, 2010 | 08:21 PM
thanks guys. ill probably run it correctly. i have a spare p28 but i want a knock sensor since it will be a daily driver. a p72 is a waste of money for me seeing as i will have a p13 to just plug and play.
thanks again
adam
Old Jul 19, 2010 | 07:37 AM
92civlude's Avatar
The P28 needs an H22 basemap.
Old Jul 19, 2010 | 09:13 AM
TurboBB2's Avatar
EGR is for emissions... without it you will fail an emissions test but thats it. doesnt mess with timing or anything. just block it off with the plate like 92civlude stated and you shouldn't get an error code.
Old Jul 19, 2010 | 11:53 AM
92civlude's Avatar
Honda makes a cool EGR delete plate. p/n 18711-PM1-J00. Its inexpensive as well.
Old Jul 19, 2010 | 02:42 PM
nus_dogg's Avatar
Go Rosko EGR Plate Delete! Way cleaner.
You'll get a CEL but nothing major.
Old Jul 20, 2010 | 05:25 AM
TurboBB2's Avatar
Wow that looks good, better than the plate that i have blocking it off. I mean its not bad but, not as clean as that rosko plate delete! lol.
Old Jul 20, 2010 | 05:55 AM
nus_dogg's Avatar
Yup, I love mine and its cheap! $21.00 shipped to my door.
Old Jul 20, 2010 | 05:58 AM
TurboBB2's Avatar
Ordered it already LOL
Old Dec 13, 2011 | 06:38 PM
rival12's Avatar
Icon6 Re: any issues if i block off egr valve?
Password JDM came out with some for $15.99
They look pretty nice, Anodized it seems too. Lots of colour choices... I mean the EGR is something everyone is going to see
http://passwordjdm.com/PasswordJDM-E...P8335C325.aspx
Inmate
Mar 21, 2018 04:01 AM
Civic Racer X 7
Jun 27, 2016 08:14 PM
genpix
11
Oct 30, 2004 04:21 PM
zCivic
Oct 23, 2004 12:00 AM
hondaZvic
Sep 12, 2002 03:16 PM
