92 b-16a swap wit bad emission's
Old Jul 15, 2010 | 11:41 AM
92B-16HATCHY's Avatar
Default 92 b-16a swap wit bad emission's
I GOT A 92 HATCH AND IT HAS A B-16A AND AND I CANT GET IT 2 PASS EMISSION'S and theres no check engine light. WUT CAN I DO 2 GET IT 2 PASS? IF SUM1 CAN HELP ME WIT THIS ID B VERY GREATFULL
Old Jul 15, 2010 | 11:53 AM
Former User's Avatar
Default Re: 92 b-16a swap wit bad emission's
What is the reason for failure?
Old Jul 15, 2010 | 12:05 PM
its runnin rich
Old Jul 15, 2010 | 12:11 PM
Needs a tune up?
Fuel pressure too high or wrong fuel injectors?
Bad ECT or O2 sensor?
Engine running cold due to stuck open thermostat?
Exhaust leak?
the hydro carbons r way 2 high. requirements 4 the dmv is 221 and its in the 500 and 700 hundreds but that wuz after i did the timing. b4 i did the timing it wuz in the 1200 and 1300 hundreds
Old Jul 15, 2010 | 12:14 PM
thank u were very helpful.
Old Jul 15, 2010 | 12:16 PM
azandford's Avatar
PM me bro... i got through emissions w/o doing anything other than pulling a hose on the intake manifold
Old Jul 15, 2010 | 12:17 PM
wut hose
Old Jul 15, 2010 | 12:20 PM
I forgot about timing. Make sure you use a timing gun to check the ignition timing when the service connector is jumped. The pointer should align with the RED mark on the crank pulley.
Old Jul 15, 2010 | 12:30 PM
the timing wuz dun and it dropped in half
Old Jul 15, 2010 | 12:37 PM
Check the other items I mentioned.
Old Jul 15, 2010 | 12:40 PM
thankz ill do that ill let u kno.
Old Jul 15, 2010 | 12:43 PM
SLURS's Avatar
or **** it do a illegal smog!! thats what i did with my b20
Old Jul 15, 2010 | 12:50 PM
wut u mean smog?
laloquera916
Oct 19, 2010 07:26 PM
kicken90crxsi
Sep 9, 2009 06:53 AM
jedi03
Aug 24, 2007 10:29 PM
ESCALVANTE
Jul 30, 2002 03:56 PM
