no antifreeze in car
Old Sep 15, 2002 | 04:04 PM
chirp2hrd's Avatar
Default no antifreeze in car
if there is very little to no water coolent or antifreeze in the radiator , will the car's idle go up and down up and down when warm??? cause i have an integra computer and it isnt throwing any codes on my b16
Old Sep 15, 2002 | 04:23 PM
chirp2hrd's Avatar
Default Re: no antifreeze in car (chirp2hrd)
car idles fine till gets warm and then idle goes up and down up and down up and down and wont stop, could this be cause there is not enought antifreeze, or water, or is the O2 sensor broken , this is open header no exhaust and i have no check engine light ?? any one know why its idle liek that
Old Sep 15, 2002 | 07:54 PM
Malgerus's Avatar
Could be a few things. Check your coolant level, IACV, timing, look for vacuum leaks, do a basic tuneup, check your PCV valve.
Old Sep 15, 2002 | 08:24 PM
chirp2hrd's Avatar
Default Re: no antifreeze in car (89_Y_49RIP)
so ur saying coolent would be a reason it would be doing this the idleing?
Old May 24, 2003 | 10:39 AM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
I have the same problem on my B16
Modified by SeaBass at 7:52 PM 5/24/2003
Old May 24, 2003 | 10:45 AM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chirp2hrd &raquo;</TD></TR><TR><TD CLASS="quote">so ur saying coolent would be a reason it would be doing this the idleing?</TD></TR></TABLE>
Why wouldnt you just check the antifreeze and if its low add some and see if it helps? I doubt that it has anything to do with no antifreeze in there but I guess you never know?? But I would just check it fill it if needs be and then go from there. Its such an easy step why wouldnt you want to check the coolant level??
Old May 24, 2003 | 07:15 PM
90da's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chirp2hrd &raquo;</TD></TR><TR><TD CLASS="quote">if there is very little to no water coolent or antifreeze in the radiator , will the car's idle go up and down up and down when warm??? cause i have an integra computer and it isnt throwing any codes on my b16 </TD></TR></TABLE>
Yes it will. On Hondas when the coolant is low, the idle surges. I think it is because the coolant temp sensor doesn't read properly, and can't decide if the engine is hot or cold so it keeps kicking the high idle in and going back to normal.
duscar
Feb 25, 2008 02:24 PM
wallabee32
Feb 6, 2008 04:18 PM
94sohcEx
Sep 23, 2004 12:25 PM
volkracing99
Jan 24, 2003 07:45 PM
chirp2hrd
19
Sep 19, 2002 09:24 PM
