throttle cable help
Bump for annoying problem. JDM motor is starting to **** me off. Does anyone know if the 99 si throttle cable will fix this problem. As far as I know you should use it because it is a few inches shorter but will this slack that is taken up help us fix the problem with the bracket location on the RHD motor. Also anyone know which rad hoses to use I will search but if anyone knows off hand it would be nice.
95 del sol vtec (b16a3) definetly fits I used it on mine
http://www.hondapartsunlimited.com/i...&submit=submit
00917880-SR3-A02 WIRE, ACTUATOR 1995 DEL SOL
double check the part # I ordered the wrong one the first time
2camsaam
Sep 12, 2003 08:20 PM
