Exhaust is spitting rust coloured liquid
Old Jul 14, 2010 | 06:52 PM
Dontoh's Avatar
Default Exhaust is spitting rust coloured liquid
anything to worry about? came across my mind that it's just condensation mixin up with a bit of rust, but could it be anything serious? **** spits all over the back of my car
Old Jul 14, 2010 | 09:50 PM
jus2phast4uLGT's Avatar
Default Re: Exhaust is spitting rust coloured liquid
same problem here...i'l keep lookin for the pro's to chip in..
Old Jul 14, 2010 | 11:23 PM
MntlKase's Avatar
Normally coolant tends to become a rust color when its old\dirty\contaminated. If it is in fact that coming out of ur exhaust you could possibly have a headgasket leaking coolant into your cylinders somewhere. Hence fix it soon!
Old Jul 15, 2010 | 01:52 AM
BlackDeuceCoupe's Avatar
HT White Ops
Originally Posted by Dontoh
[...]came across my mind that it's just condensation mixin up with a bit of rust[...]
That would be my 'best guess' too...
Gasoline produces a gallon of water, for every gallon burned.
Until your exhaust gets to normal operating temps, the water condenses and drips out the tailpipe.
In the old days, OEM muffs had a little pinhole on the bottom-side, and this condensation just dripped out on the pavement, before you ever saw it. But, I don't think they do that any more.
Anyway, my only concern would be... how much life is left in my rusted out mid-pipe, et cetera, before it breaks loose and is dragging under my ride?
That's probably not much of a concern. Just saying...
Old Jul 15, 2010 | 06:01 AM
Dontoh's Avatar
good info, good info.. i was told that my exhaust was ghetto rigged together by the old owner, so i'll check that out first.. hope its not the head gasket, although that would give me an excuse for a swap
Old Jul 15, 2010 | 06:43 AM
98civdx's Avatar
Master Detailer
I would worry, no big deal.
Every car does it, but switch out that ghetto exhuast
Old Jul 15, 2010 | 08:11 AM
AGENT_47's Avatar
yeah don't be like me and wait for your entire exaust system to fall off right at the resonator at 3am in the rain on the highway at 90mph
Old Jul 15, 2010 | 08:12 AM
Dontoh's Avatar
lmao, bet that **** sucked.. guess i'm lookin into exhausts now.. should get the swap in gear! motivation, motivation, motivation lol
Old Jul 15, 2010 | 08:54 AM
vtechjunkie's Avatar
Ya, I would think that it's the rust in the exhaust system, mixing with the normal moisture that usually builds up. If the car is running a bit wierd, or what-not, then I owuld look at the headgasket.
Old Jul 15, 2010 | 08:58 AM
Dontoh's Avatar
it does idle around 1500+\- for about 30 seconds then drops to around 1k and sputters like a bitch
Old Jul 15, 2010 | 09:11 AM
Former User's Avatar
Liquid water (condensation) dripping from the exhaust really should only be seen when the engine is not fully warmed up because when the engine and exhaust system are hot, water produced by combustion should be converted completely to water vapor (gas).
Old Jul 15, 2010 | 09:18 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Correct. Just to add. However, exhaust is much hotter near the cat vs the tailpipe area. So, true. Water should burn off. But sometimes when it gets push way back and collects in the muffler, the exhaust does not get "that hot" enough to burn that much off right away.
It sits and collect. And when you WOT, it spits some of it out.
Old Jul 15, 2010 | 09:33 AM
Dontoh's Avatar
makes a lot of sense.. it hasn't been driven for close to 10 months, just in and out of the garage.. after i got the sound system working in it the rpms when idling dropped to around normal so i'm not too worried about that.. i'll give it about a week, if the liquid is still rust color that exhaust is going
I could see this happening, especially in cold weather or when the car is only driven on short trips where the exhaust system does not get fully heated for an extended period of time. Nonetheless, I think a properly working exhaust system should get hot enough during average drives to boil off any water that might pool in muffler. However, damaged exhaust systems, such as those being discussed in this thread, might be an exception to this generalization.
W95civicEXcoupe
11
Apr 2, 2015 09:57 AM
Ilovemyef9
Jan 1, 2011 03:17 AM
FRKWOO
Jul 24, 2009 11:17 AM
bananacruzier
Apr 2, 2002 10:27 AM
