Exhaust is spitting rust coloured liquid
anything to worry about? came across my mind that it's just condensation mixin up with a bit of rust, but could it be anything serious? **** spits all over the back of my car
Re: Exhaust is spitting rust coloured liquid
Normally coolant tends to become a rust color when its old\dirty\contaminated. If it is in fact that coming out of ur exhaust you could possibly have a headgasket leaking coolant into your cylinders somewhere. Hence fix it soon!
HT White Ops
Gasoline produces a gallon of water, for every gallon burned.
Until your exhaust gets to normal operating temps, the water condenses and drips out the tailpipe.
In the old days, OEM muffs had a little pinhole on the bottom-side, and this condensation just dripped out on the pavement, before you ever saw it. But, I don't think they do that any more.
Anyway, my only concern would be... how much life is left in my rusted out mid-pipe, et cetera, before it breaks loose and is dragging under my ride?
That's probably not much of a concern. Just saying...
good info, good info.. i was told that my exhaust was ghetto rigged together by the old owner, so i'll check that out first.. hope its not the head gasket, although that would give me an excuse for a swap
yeah don't be like me and wait for your entire exaust system to fall off right at the resonator at 3am in the rain on the highway at 90mph
lmao, bet that **** sucked.. guess i'm lookin into exhausts now.. should get the swap in gear! motivation, motivation, motivation lol
Ya, I would think that it's the rust in the exhaust system, mixing with the normal moisture that usually builds up. If the car is running a bit wierd, or what-not, then I owuld look at the headgasket.
Liquid water (condensation) dripping from the exhaust really should only be seen when the engine is not fully warmed up because when the engine and exhaust system are hot, water produced by combustion should be converted completely to water vapor (gas).
It sits and collect. And when you WOT, it spits some of it out.
makes a lot of sense.. it hasn't been driven for close to 10 months, just in and out of the garage.. after i got the sound system working in it the rpms when idling dropped to around normal so i'm not too worried about that.. i'll give it about a week, if the liquid is still rust color that exhaust is going
Correct. Just to add. However, exhaust is much hotter near the cat vs the tailpipe area. So, true. Water should burn off. But sometimes when it gets push way back and collects in the muffler, the exhaust does not get "that hot" enough to burn that much off right away.
W95civicEXcoupe
11
04-02-2015 09:57 AM
FRKWOO
07-24-2009 11:17 AM
