Can you swap 89 Accord /87 Prelude Trannys'?!?!?!
Old Sep 15, 2002 | 03:37 PM
z-partsman's Avatar
Default Can you swap 89 Accord /87 Prelude Trannys'?!?!?!
HELP!!!!!! PLEASE!!!!!!!!!! can you swap out and 89 Accord trans. over into an 85 Prelude?????? My Trans went out in the Prelude and I have a friend that has an Accord sitting around with a bad engine. Is this swap able to be done so I can get my car back on the road <U>ASAP!!!!</U> Like Tomorrow ( Mon. the 16th?) MY has been broken till I this out.
Thanks!!!!!!!!!!!
Old Sep 15, 2002 | 09:51 PM
89_LXi's Avatar
Default Re: Can you swap 89 Accord /87 Prelude Trannys'?!?!?! (z-partsman)
Yes, it should be a direct swap. Check out http://www.3geez.com/showthread.php?s=&threadid=165 for a little better explanation. It's for a Prelude to Accord tranny swap, but the opposite should also work the same. The gear ratio's will be a little different though
jsnappdaddy88
Nov 7, 2014 10:10 PM
Jdmjunky13_
Apr 5, 2012 06:21 PM
hondaracin24
Dec 21, 2006 01:53 PM
86ACCORDDIPPIN
Jan 14, 2005 11:22 AM
