H Swapped eK clutch job-drop or pull
so it seems ive done just about everything on h swapped tegs and civs except for a clutch job so far so i ask before hand to give my self a little insight
can the trans still be droped or must the whole engine be pulled?
i guess i should say the reason i ask is if were going to pull the motor
out now im going to do alot mo0re to it than just change a clutch, i need to get some parts if its the case...
Its not that hard. Two people job but can be done with one. Just loosen the T bracket in the rear, and trans mount. You can also loosend the driver side mount to let the engine come down a bit more with out twisting the mounts polyeurathane. Youll be fine. Its easy as any other clutch job.
rhdins
10
Jul 27, 2011 07:16 PM
da_coolest
10
Jun 30, 2009 12:15 AM
Pnoyej6
Apr 3, 2007 10:09 AM
