Bottoming out?
Old Sep 15, 2002 | 01:34 PM
performula's Avatar
Default Bottoming out?
Old Sep 15, 2002 | 02:24 PM
keithv's Avatar
Default Re: Bottoming out? (performula)
easy fix... raise the car up!
if you are bottoming out the bottom of your car, you are way too low...
Old Sep 15, 2002 | 02:33 PM
bryant's Avatar
Default Re: Bottoming out? (breaka_1_9)
stiffer springs. or better shocks
Old Sep 15, 2002 | 06:06 PM
illusive's Avatar
Its probably your struts on your car. Your struts are farely old and stock ones dont handle lowering that well when there older. Mine bottomed out alot in the front after I lowered it, so I went out and picked up some tokico struts and havent had a problem since. But I'm only dropped 2.5front 2.25rear and if your cars dumped may be just to low as well.
Old Sep 15, 2002 | 06:52 PM
Losrocket_'s Avatar
Default Re: Bottoming out? (illusive)
Your car has to be really really low to bottom it out driving down the road. Your either hearing your struts bottom out or your upper control arms hitting your strut towers but i doubt the car itself is bottoming out. My car is fairly low and when i hit a bad bump my upper arms hit the strut towers. It makes a fairly loud bang.
Old Sep 16, 2002 | 07:08 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Bottoming out? (Losrocket'91)
is the car in your avatar yours?
if it is, you're prolly only hitting the sides of the body kit.
like Losrocket said, hard to bottom the belly of the car.
Old Sep 16, 2002 | 09:29 AM
Bontke's Avatar
Default Re: Bottoming out? (two.oh)
Were the bump stops cut when the springs were installed? If the bumpstops weren't them they will cause the car to bottom out easier.
Old Sep 18, 2002 | 04:04 AM
Bontke's Avatar
"I cannot get the collar with the little tab all the way down"-
What part is that? WHat do you mean that you had to saw the brake fittings off? If I am correct, the front struts have a designated left and right side. It all depends on this metal piece that the brake line goes into to clip down....you didn't cut that off did you?
Old Sep 18, 2002 | 09:17 AM
1990hondaHF's Avatar
I bottom out and I don't have aftermarket struts or springs. I doesn't happen often but enough to **** me off. What sucks is that when I do get it lowered, I need to get new struts as well....more $$$$...but I'm sure it will ride SWEEET!
Old Sep 18, 2002 | 09:39 AM
Max_ED9's Avatar
Default Re: Bottoming out? (1990hondaHF)
yea i got kyb agx and for some reason the passenger side fork didnt want to go over the shock at all... i take out the shock and the fork and BAM like butter it slides right in. im like wtf. so i try again in the car and it wont go in again... so i said F*** it and took the fork out and stretched the **** out of it. then i got the shock and sanded the bar down to metal and used some hodna grease... that **** went right on.... it was a PITA!
Old Sep 18, 2002 | 04:22 PM
tysf's Avatar
more than likely you're just scraping the mudflaps... it sounds a lot harsher than it really is
but if you are bottoming out the body at stock ride height you need to drive a LOT more carefully or you're gonna tear your front bumper off with it lowered
ive only dragged the body like twice (both times going really slow, up a savage curb) normally i just tear pieces of my exhaust off rather than drag the body
[Modified by tylerspec, 1:23 AM 9/19/2002]
kixcrx
Jan 1, 2007 11:40 AM
94BlueGSR
Sep 10, 2006 10:54 AM
dailygirl
Jun 13, 2004 03:39 PM
aeon
Apr 7, 2004 05:40 AM
Ignitecivic
May 31, 2002 07:54 AM
