questions on shocks..
Old 06-13-2004, 02:39 PM
dailygirl's Avatar
Default questions on shocks..
a couple of months ago, i installed some tokico high performance shocks on my car, thinking that my ride would be better, the back seat of my car is still very bouncy but my front is fine. what's a good setting for it??? I've tried all. I like the 3 in the front and 5 in the back but the back would be too stiff that it feels like my car is taking too much pressure from the bumps. any recommendation???
Old 06-13-2004, 02:40 PM
-Gambit-'s Avatar
Default Re: questions on shocks.. (dailygirl)
soften up the back, try going to like a 3 in the back and if its still to bouncy for you go even softer. 5 is the stiffest and 1 is the softest. But the fronts at 3 will be fine or daily driving
Old 06-13-2004, 02:42 PM
Solscud007's Avatar
Default Re: questions on shocks.. (Geeky_Gambit)
is your car lowered too? you may want to check the clearance on your bumpstops if it is lowered. Often times you need to cut the bump stops in half. Other wise your car is using the bumpstop as a shock absorber and the result is bouncy ride.
Old 06-13-2004, 02:53 PM
dailygirl's Avatar
Default Re: questions on shocks.. (Solscud007)
my car is 1 and a half inch dropped. after installing the shocks is it suppose to lower my car even more? i had to raise my ground control springs so my car wouldnt be slam. is that normal?
Old 06-13-2004, 03:09 PM
duh blacksheep's Avatar
what tires and rim size are you running?
Old 06-13-2004, 03:17 PM
dailygirl's Avatar
Default Re: questions on shocks.. (duh blacksheep)
falken 195 15 60
Old 06-13-2004, 03:39 PM
just wondering, cause if your tires are under-inflated and you have stiff shocks, it will start to bounce
those shocks shouldnt be softer than stock. check the tire pressure, its my only guess unless you have some stiff spring rates.
bb4socal
11-23-2005 05:35 AM
aeon
04-07-2004 05:40 AM
drunknmunkypow
03-24-2003 12:33 PM
DC Sports EJ8
12-30-2002 10:54 AM
Red!ine
10-25-2002 03:44 AM
Quick Reply: questions on shocks..
