2000 accord Lx auto shutting off radomly
Old Jul 13, 2010 | 07:15 AM
osofastferu's Avatar
Default 2000 accord Lx auto shutting off radomly
Hi everyone,
The engine has been shutting off radomly on me, and it only happens while Im stopped at a light or stop sign. It has never shut off on my while I am in motion. When it shuts off , the engine sputters a bit and then it shuts down, usually takes a few minutes to get it started back up.
things i've replaced
1. Distributor Cap &Rotor
2. Coil
3. ICM
4. Spark plug wires
5.Ignition switch
6.Fuel pump
after replacing all these things the car still does it, it doesn't do it everytime i come to a stop but it'll only do it while im stopped.
anyone have any ideas? could spark plugs be to blame?
Old Jul 13, 2010 | 10:53 AM
Default Re: 2000 accord Lx auto shutting off radomly
ok just changed the spark plugs, definitly not it, cuz the car isn't even starting now
Old Jul 13, 2010 | 12:27 PM
phootbag's Avatar
Do you have any DTC's?
Old Jul 13, 2010 | 05:50 PM
what are DTC'S? and I've noticed that when I turn the key I no longer hear the fuel traveling thru the lines, So im going to replace the relay next.
Old Jul 13, 2010 | 06:18 PM
phootbag's Avatar
I predict your problem will be fixed.
DTC's are Diagnostic Trouble Codes. The main computer runs tests at various times. These tests are labled with titles called DTC's. P0740, P0135 etc. They can help in diagnostics because they are a specific test the ECM saw a problem with.
DTC's are indicated by a Check Engine Light.
Old Jul 13, 2010 | 06:31 PM
Oo, well the check engine light never comes on, even when the car actually shuts off the engine light doesn't throw any codes, however the light does work ,cuz it comes one when i first turn the key.
Old Jul 14, 2010 | 05:59 AM
***update*** im posting this just in case someone else has this problem, it was the main relay, it very easy to get to in this model honda. I popped the new one in and it started up immediatly, and i checked the old one and it had fried soldering points on it. thanks for the help everyone
Old Jul 18, 2010 | 10:28 PM
boost and bass's Avatar
Hi i'm having a similar problem my car recently stalls while trying to start it seems like it almost catches then stalls and all the lights appear on the dash including all the door ajar and brake lights, it has also happened while running a few times always stopped never rolling like you said. Where these your symptoms, it might be the same problem?
beberle
Apr 15, 2016 03:04 AM
crexsi
May 8, 2009 06:44 PM
ezol
Mar 28, 2007 07:42 AM
filip-s
Oct 26, 2006 07:22 AM
