EG-GSR F & R disc brake conversion ?
if you've swapped your front knuckle for 94-00 integra
(regardless if it is from an LS, RS, GS or GSR, all front calipers are stamped 17CL14VN & use a 10.3" front rotor)
& swapped your drums on your eg for rear disc,
the 40/40 valve from the RS is the correct.
valve prop from any 88-00 civic or 90-01 integra with rear disc will work
* since you're planning to use bigger calipers, you'll nedd to upgrade your master cylinder,
a 90-91 civic EX sedan 15/16" MC will bolt on to your current EG booster
no bending or re-flaring lines
honda oem part # 46100-SH4-A11
use caution when dealing with the m/c & use a flared wrench to avoid stripping it.
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
hey man i have a question for you. im in the process of doing the same thing on my 93 del sol and was wondering what parking brake lines/cables did you use?
on your 93 del sol S, if you're converting to rear disc brakes
...you can always source the e-brake cables you'll need;
#9 : oem honda part #47520-SR2-933 * WIRE B, R. PARKING BRAKE (DISK)
#11: oem honda part #47521-SR2-933 * WIRE B, L. PARKING BRAKE (DISK)
# 1 : oem honda part #43471-SD2-930 * PIN, BRAKE WIRE END (X2)
#17: oem honda part #90705-SD2-931 * PIN, SNAP (6MM) (X2)
search under 93-97 del sol Si or 94-97 del sol VTEC:
http://www.hondaautomotiveparts.com/...=PARKING+BRAKE
kirkland08
14
Mar 17, 2011 08:58 PM
