Mini-Me Help!!!
Ok, I'm preping to do a mini-me swap and would like to run my parts list by someone who has done one before...let me know what you think and if I'm missing something...
Car: '92 Civic LX
Eng: D15B7 ( new pistons, rings, rod bearings and thrust washers )
Head: D16Z6 ( Remachined surfaces, grinded valve seats, all new gaskets and O-rings, new valve seals )
IM: D16Y8 ( Removed all sensors-using OBD1 components, y8 fuel rail, B7 injectors )
ECU: P28 ( virgin-not chipped )
Misc: - Like I said all new gaskets, o-rings and head bolts, metal Z6 head gasket, IM, EM, VC, OP
- Z6 timing Belt, Skunk2 Adj Cam Gear
- a couple feet of both vacuum and fuel line
- Spray Gasket, assembly grease, mp lube
- Oil Filter (B7), Oil, Coolant
- 18 gauge wire, to wire ecu to vtec solenoid and oil pressure switch
Hope I have everything gonna start Friday if possible...
Car: '92 Civic LX
Garcia505
Apr 20, 2011 04:35 PM
dc5mikeydc5
11
Oct 7, 2005 08:24 PM
firstgenrex
Oct 15, 2003 09:05 PM
