Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 crv - rear differential fluid?
Old Jul 12, 2010 | 11:57 AM
Charlie Moua's Avatar
Default 2000 crv - rear differential fluid?
Okay the rear diff is starting to make some noise, so I figured it's time to change out the fluid. What kind of fluid can I use?
OEM - lucas - any gear oil at autozone?
how many quarts will I need to fill it up?
Thanks - Charlie
Old Jul 12, 2010 | 12:24 PM
eghatch4sale's Avatar
Default Re: 2000 crv - rear differential fluid?
i would just go to the dealer for it i think it was dual pump 8.50 a quart
Old Jul 12, 2010 | 05:51 PM
Duane_in_Japan's Avatar
It may be like gear lube, it may be like tranny fluid viscosity, get it from the dealer and some additive also, stabilizer of some sort for older diffs. Inspect for leaks, clean them up and be prepared for a regular inspection and refill if you have a leak.
Old Jul 17, 2010 | 06:16 PM
oroblram's Avatar
oem dual pump 2 is good and quiet.
Old Jul 17, 2010 | 09:12 PM
qwrty's Avatar
use OEM fluids....
itll save you time and hassles in the future!
Old Jul 17, 2010 | 10:34 PM
Sordz's Avatar
Like everyone else said, OEM fluid for sure, buy 2 quarts it takes just over 1 to drain and fill. You should change it more often than what it sounds like you do, same with valve adjustment. Good luck
Old Jul 17, 2010 | 10:57 PM
Sordz, you have reached a milestone in your H-T post history, 69 posts, its time for you to upgrade to a real avatar and get rid of that noob looking thing there toughguy.
Old Sep 9, 2010 | 06:50 PM
johncrash's Avatar
dual pump is the fix if real bad you might have to do ittwice
codysam
Aug 20, 2017 07:44 AM
chazt
Apr 6, 2013 02:26 AM
shawnlee250
Honda Civic (2001 - 2005)
Aug 9, 2011 07:40 PM
aquabob89
Jan 30, 2006 03:37 PM
EGhatched
Feb 28, 2002 08:50 PM
