third gear grind
* B A N N E D *
third gear grind
If i were to change my transmission fluid would it get better or prevent other synchronizers from going out. or should i just get new synchronizers.
Re: third gear grind (aquabob89)
I had a little grind in 3rd gear once I changed my fluid and it is smooth now. It depends on how bad the syncros are and what fluid you are using. I would change the fluid and if still happens then change the syncros
Re: third gear grind (civic_driver_389)
if u want a temp fix, try gm syncromesh, it has to be friction modified, look it up theres like 100 post's about the wonders it works.
_decker
10-09-2017 06:42 PM
selfmade0086
Transmission & Drivetrain
06-03-2013 07:12 PM
