Alternator Belt Size b18c
Old Jul 12, 2010 | 07:11 AM
spags930's Avatar
Default Alternator Belt Size b18c
I just got my B18c motor in today and the alternator belt is not on it. can someone tell me what size i would need for the alternator belt.
thanks.
Old Jul 12, 2010 | 08:12 AM
spags930's Avatar
Default Re: Alternator Belt Size b18c
bump
Old Jul 12, 2010 | 09:31 AM
300whpej's Avatar
autozone.com, I honestly can't see the jdm motor needing a different belt.
Old Jul 28, 2010 | 10:48 AM
RGuo921's Avatar
i seriously don't understand why do people have to be such douches, when all it takes is a simply answer to help a fellow h-t member.
i am in the same pinch...and i didnt bother posting up a thread because i've already seen similar threads that are only answered with smart *** replies that leaves the thread poster nowhere...so I am going down to kragen and i am getting me a 1999-2000 si alternator belt, because i've tried getting the gsr and there is way too much slack.
the reason why i am going with a 1.6L alternator belt is because i've notice some other parts from the b16a can be acceptable with the 1.8L type r JDM spec.
i hope this helps...and if anything i'll let you know if it works or not.
Old Jul 28, 2010 | 12:15 PM
raidacaipo's Avatar
any belt that is short enough to use it good. That way you don't have to put so much effort into trying to make it tight. You can try and ask autozone what size belt you would need and they will look it up on their computer. Most likely they will have an answer for you. Good luck
southernSCHEME
22
Jun 28, 2011 06:26 PM
Eighty-Nyne
Jun 10, 2009 07:10 AM
r3v da t3g
Mar 4, 2007 08:58 AM
VWkila
Jun 8, 2004 05:25 PM
TAGURIT
Mar 12, 2004 11:18 AM
