Knocking sound from H23V
Old Jul 11, 2010 | 05:31 PM
Blazin Si's Avatar
Loved
Community Favorite
Default Knocking sound from H23V
This motor swap is only a month old and it started knocking yesterday. I've had a motor spin a rod bearing once before so I know what that sounds like. This seems much quieter and is less audible at an RPM that is higher than idle.
I had a shop change the timing belt. They left a bolt loose which cut the timing belt a couple days after I got the car running. Thankfully there was no damage (or so they said), but flash forward a few weeks and I'm hearing this.
Flickr video link below.
http://www.flickr.com/photos/49579200@N07/4785117910/
It sounds like metal to metal contact and I believe it coming from the head, but it's hard to say. If the timing belt were too loose and there was slack, would that cause a similar noise?
Old Jul 11, 2010 | 05:58 PM
crazyheadrush's Avatar
Default Re: Knocking sound from H23V
Ur timing may have jumped a tooth.
Old Jul 11, 2010 | 06:16 PM
Blazin Si's Avatar
Loved
Community Favorite
I just want to know if it's safe to drive. The shop I go to won't be open until Tuesday and I need to drive it to work.
The knocking can't be heard when the car is being driven. Even with the windows down and my head out the window, I can't hear a thing. It's only at idle and it seems to speed up as the RPM rises, but it also get quieter. It can't be heard above 2000 RPM.
Old Jul 11, 2010 | 08:13 PM
InvaderTrax's Avatar
If it's not getting worse, you can't hear it when you drive, you can't find a ride to work, and you want to chance it, then drive carefully on it
chipper
10
Jul 4, 2013 10:59 AM
skiakhokie
Honda Civic (2001 - 2005)
Mar 24, 2012 04:35 AM
hometheaterman
12
Sep 1, 2011 05:05 PM
Nutcase4life
Oct 24, 2007 10:48 AM
Bictorious
12
May 5, 2004 07:56 PM
