Boosted OEM P30, Max ign adv. ?'s
Old Jul 11, 2010 | 10:27 AM
2000CTRSi's Avatar
Default Boosted OEM P30, Max ign adv. ?'s
Crome P-28:
Currently I have the car at around 17.25 deg at about 9.4psi... and 15.75 @ about 11.2... on a 57 trim
I have run into problems with ringlands on these pistons, and am a bit shaken by their temperment. Seeing how crome and freelog are limited, I really cannot get a good idea without some det. cans how far to go...
Anyone chime in on what their max adv. is past 6500 on an oem build? Specifically on a 10.5 motor
I run 18deg on every other motor but this one
John, chime in !
Old Jul 11, 2010 | 01:31 PM
2000CTRSi's Avatar
Default Re: Boosted OEM P30, Max ign adv. ?'s
De pinga! I thought this area had mas traffico. Wow!
Old Jul 11, 2010 | 08:51 PM
mtber's Avatar
Timing values mean nothing if you don't have your distributor synced to your engine management.
Also, Crome = lacks proper ignition timing control = table values don't mean a whole lot = you must tune around this "bug".
Switch to a software that doesn't have issues. Hondata, eCtune, Neptune etc.
Old Jul 12, 2010 | 12:36 AM
2000CTRSi's Avatar
If it were that easy, I would just be datalogging the proper parameters and not be asking this.
Of course I have synched the distributor. I am by no means a novice. I havn't taken this particular setup to the dyno yet so I was getting an idea.
I am sure you have tuned several vtec turbo motors W/ oem pistons. Just curious on what others have their ign adv @... aroud the same boost levels... Most of my maps are for built motors... but without logging knock, its hit or miss to me...
Looks like I will be heading to Radioshack to build a $25 set of DET's... Until I stumble across a cheap s300
Old Jul 12, 2010 | 02:56 AM
mtber's Avatar
Not trying to be harsh but what did you expect for a reply?
Some one to come on here & post that their sohc is running X amount of timing at x rpm on crome & have it work for you?
That would then make you feel better about running that value for ignition timing without actually knowing what is going on due to a lack of dyno time, plug reading, det cans etc?
You should tune a built motor no different then a motor with stock pistons when it comes to ignition timing. Detonation is detonation & will hurt any piston (cast or forged).
Asking for such feedback on a forum sounds like a "novice" to me. There is no pride in sounding like an "expert" or claiming your not a "novice".
Old Jul 13, 2010 | 02:00 PM
2000CTRSi's Avatar
pm'd
Corksil
32
Jul 2, 2011 04:24 PM
wasanissanFL
10
Oct 3, 2010 09:27 PM
2000CTRSi
Jul 12, 2010 07:50 AM
jDMJeRk
Mar 10, 2004 06:54 AM
badazzaccrd
Feb 12, 2004 05:59 AM
