Honda CR-V & Element 2WD & 4WD Element & CR-V
HELP! 911... b20b head rocker arm
Old Jul 10, 2010 | 04:17 PM
ARMED's Avatar
Default HELP! 911... b20b head rocker arm
ok, i was adjusting my valve clearance, and while tightening one of the
exhaust valve...(where you put the flat screw driver and the 12 wrench)
the thing just came off...thats the rocker arm correct? theres like a little ball thing
that supposed to be seated on a nut (the end of the screw thing that you adjust)
well that whole thing came off and i couldnt put it back...
any help..
or call me..
for faster help
317 223 1732
june
Old Jul 10, 2010 | 04:40 PM
ARMED's Avatar
Default Re: HELP! 911... b20b head rocker arm
ok i manage to put it back, i used a big flat screw driver and pushed the
valve/spring where it goes to...is that the right way? i couldnt put put it before
because it would fit and all that, i made a room by pushing the spring and then
placed the rocker thingy in there..
is it going to come off?
or is time for a vtec head?
Old Jul 10, 2010 | 04:43 PM
EH2ridinDIRTY's Avatar
it the little ball stil on top of the nut in your head
Old Jul 10, 2010 | 04:44 PM
cause the rocker arm just sits on top its heald down by the cam on top only
Old Jul 10, 2010 | 06:22 PM
ARMED's Avatar
it came off...
i just could put it back at first...
fixed it, pushed the spring then inserted the thing....its good now thanks man
Old Jul 10, 2010 | 08:15 PM
qwrty's Avatar
good thing your engine is good now....
may be time to upgrade/mod it!
LOL...
Old Jul 10, 2010 | 09:15 PM
ARMED's Avatar
i got kinda scared earlier, i thought something broke off...
i was like fu(k...then in my head i was like good (vtec head)
its ok now, i had to dod it twice at first i used .008 exhaust and .005 intake
then i started hearing a ticking noise...
then did it with .007 exhaust .004 intake...then everything went good
djkobe
Apr 13, 2011 09:32 AM
SrT4u2nV
May 2, 2006 02:02 PM
EF'n
May 31, 2005 01:56 PM
$300lude
Oct 10, 2004 06:36 PM
StolenTeg
Apr 17, 2004 11:28 AM
