00' civic Brake Light Switch problems
Old Jul 10, 2010 | 02:22 PM
putzkrieg's Avatar
Default 00' civic Brake Light Switch problems
Hi all, first post. Came out of the grocery store and couldn't shift from park. Checked the brake lights, they do not come on when the pedal is pressed. Took a look, noticed a black wire dangling near the switch assembly. Not sure if this is from the switch or just a random wire. Everything else working ok. Any advice on the mystery black wire or replacing the switch would be much appreciated. Thanks!
Old Jul 10, 2010 | 02:58 PM
Former User's Avatar
Default Re: 00' civic Brake Light Switch problems
Sounds like a bad brake light switch. Is the button stuck in after the pedal is pressed?
Old Jul 10, 2010 | 09:15 PM
putzkrieg's Avatar
No, it isn't stuck in. It pops right back out like it should, which lead me to believe it has something to do with that mysterious detached black wire. But i don't clearly see anywhere it might've come from.
Old Jul 10, 2010 | 09:37 PM
Have you checked the brake light fuse under the hood?
There's no black wire under the dash for the brake lights. Use a multimeter to test whether the brake light switch fails to close when the pedal is pressed.
Old Jul 10, 2010 | 09:40 PM
putzkrieg's Avatar
thanks for the tip, will try tomorrow. I suppose my main concern is that it will not shift from park without putting the key in the release slot.
Old Jul 10, 2010 | 09:43 PM
It's 15A hood fuse 52:
Old Jul 10, 2010 | 09:44 PM
putzkrieg's Avatar
wonderful, thank you! would this fuse being bad also cause it to not shift from park? or only a bad switch?
Old Jul 10, 2010 | 09:47 PM
A bad brake fuse or switch would prevent shifting out of Park.
Old Dec 3, 2010 | 07:14 AM
dhouse260's Avatar
Same problem on my accord. Would this fuse also cause the brake lights to not come on even after I manually override the shift lock? Because just like putzkrieg the switch goes back and forth when the brake pedal is pressed just like it is supposed to.
Old Dec 3, 2010 | 07:19 AM
putzkrieg's Avatar
Replacing that fuse fixed the shifting problem and the lights for me, so hopefully it will for you too.
USA
Lighting
Apr 30, 2019 06:38 AM
KelvinR
Sep 10, 2012 02:38 PM
jasoncanseeoh
Mar 11, 2010 08:30 PM
Padronis
Jun 29, 2005 08:13 AM
