mpfi swap questions
Old Jul 10, 2010 | 12:11 PM
efjones9's Avatar
Default mpfi swap questions
Doin a mpfi swap and I am using obd1 injectors, I soldered all 5 of the wires together. I was wondering if I have to splice the yellow/blk wire with the injector resistor. Or do I just run the. Injector resistor straight to A15?
Old Jul 10, 2010 | 12:42 PM
BiG ChOr!Zo's Avatar
Default Re: mpfi swap questions
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/d-i-y-faq-obd-0-obd-1-pinouts-conversion-help-1319235/
Old Jul 10, 2010 | 04:15 PM
efjones9's Avatar
Gracias
Old Jul 10, 2010 | 05:32 PM
efjones9's Avatar
Can't see the end of the pic!
Old Jul 10, 2010 | 09:32 PM
dohc4life's Avatar
obd1 injectors dont use resistor box you just solder all the power wires to the dpfi injector power wires the 2 yellow black to the 4 power
Old Jul 11, 2010 | 12:07 AM
Clipsed's Avatar
Ylw/Blk goes to a13 and a15 as well as over to your main relay.
Old Jul 11, 2010 | 08:36 AM
dr_latino999's Avatar
Old Jul 11, 2010 | 03:51 PM
efjones9's Avatar
Ok so the blk/yellow injector resistor wire goes to a15 and a13? Ill try that. I can't get the injectors to fire
Old Jul 11, 2010 | 06:13 PM
Clipsed's Avatar
it should also go to your main relay, use a DMM and check for continuity.
crxcess
10
May 26, 2006 09:56 AM
ZCcivicBOI
Sep 9, 2005 10:57 AM
fearless_dsm
Mar 10, 2004 04:24 PM
EGHatchy
Jul 13, 2002 08:53 AM
