How do you flush the brake fluid?
Old Sep 15, 2002 | 10:56 AM
FourthGenHatch's Avatar
Default How do you flush the brake fluid?
I want to replace all the fluid when I do my rear disc swap so how can I flush all of the old stuff out?
Old Sep 15, 2002 | 11:19 AM
E-AT_me's Avatar
Default Re: How do you flush the brake fluid? (FourthGenHatch)
when ya gonna be doing it? all you gotta do, is sense you're pulling the lines anyway, just put on the new ones, and pump out all the old stuff through the calipers... make sure you don't run the master cylinder dry!!! that's critical!!!
if ya need any help, i don't mind... i'm in NOVA... so it's not too bad a drive..
Old Sep 15, 2002 | 11:25 AM
Default Re: How do you flush the brake fluid? (Rexman)
So basically I should just buy a huge *** box of DOT3 and then just slowly bleed the hell out until all the stuff coming out is the new stuff?
Old Sep 15, 2002 | 12:19 PM
REX VT's Avatar
GET IT DONE BY EXPERIENCED MECHANICS!!
Not worth saving the 50$.. bleeding lines sucks *** and you always end up with air in the lines
P.S. get DOT4 or 5.1
Old Sep 15, 2002 | 03:48 PM
E-AT_me's Avatar
Default Re: How do you flush the brake fluid? (REX VT)
if you don't do it enough, then you get air.. i have successfully performed this on atleast 6 cars.. without ANY problems... i bleed my brakes once a month, due to autocrossing, and never have any trouble.. i bleed many peoples cars for track days, and they never experience a "spongy" pedal..
buy something from ATE, i use super-blue..
detaude
Honda Motorcycles
May 18, 2005 03:46 PM
216.226.142.95:27016
Sep 23, 2004 10:16 AM
RICE POLICE SIP
12
Jul 12, 2003 02:19 PM
robbin
May 27, 2002 09:27 AM
