h22 sound like a subby...need HELP!!!
Old Jul 10, 2010 | 04:22 AM
1990hf's Avatar
Default h22 sound like a subby...need HELP!!!
This is my first H Series build and it sound like a subby when start. Can't figure out why the motor sound like that and shake. I would be really appreciated if someone could help me out. Its a 97 h22a4. The head and block is stock bore with brand new parts. Head and block been hot tank, clean, and re surface.
Head: stock bore with supertech dual valve springs/retainers, skunk2 68mm intake manifold, skunk2 68mm throttle body, skunk2 stage 2 tuner cams, ngk high compression spark plugs, full 6al msd kit, 450cc dsm injectors w/resistor box.
Block: stock bore with mahn 11.5 cr piston, eagle rods, acl bearing kit, arp main stud, arp head stud.
Old Jul 10, 2010 | 05:31 AM
civiccxhatch's Avatar
Default Re: h22 sound like a subby...need HELP!!!
make sure your resistor box is right. I found one injector missing out on my swap. make sure your in time. did you have a balance shafts removed? all your mounts are tight? check and recheck.
Old Jul 10, 2010 | 06:12 AM
95DC2GS-R's Avatar
my car sounds like that when an injector clip pops off, your cam timing could also be off.
Old Jul 10, 2010 | 09:22 AM
1990hf's Avatar
Everything is plug in right and all motor mount is tight. At Cold start the idle sit at 900rpm
Old Jul 10, 2010 | 10:15 AM
projectTeG's Avatar
check if your firing on all cylinders. wet the header primaries and see if one it not as hot as the rest. i popped a wire off on a WOT pull and car sounded like a subbie.
a bad head gasket, bent valves and bad ringlands can cause this also.
Old Jul 10, 2010 | 01:21 PM
nus_dogg's Avatar
My F22B1 Bisi cammed sounded like a subie when one of my plug on the distributor came off loose at first start up.
Old Jul 11, 2010 | 07:56 AM
prelude_h22vtec's Avatar
My car sounded like this a few months back. It turned out to be a intake manifold gasket leak near Cyl 1. So at idle and up to 3k rpm, Cyl 1 wasn't firing at all. Sounded just like a Subaru. Eventually it got worse and started idling real high and I found the leak. Hope you find the problem
Old Jul 11, 2010 | 08:32 AM
InvaderTrax's Avatar
That and that you have the firing order correct
Old Jul 11, 2010 | 01:33 PM
codyh's Avatar
formerly xmod_supra
Is it so hard to spell anymore?? Haha I couldnt even understand what he was trying to ask. But good luck with your subby? (Subaru?)
Old Jul 11, 2010 | 04:43 PM
BigBlock22's Avatar
thats three cylinders running alright.... i would take a multimeter to your injector plugs to make sure they are all working. like the others said, one cylinder is probably not firing.
angelito_h22
Jan 1, 2017 08:36 PM
drkidd215
Nov 17, 2013 08:43 AM
92 CIVIC HATCH VX
Jul 19, 2006 08:29 AM
existanzcivicb20
May 11, 2006 06:32 PM
2001accord
Mar 8, 2006 03:31 PM
