sohc vtec swap
Old Jul 9, 2010 | 05:46 PM
Kool_Aid's Avatar
Default sohc vtec swap
where is my vtec switch located on my sohc vtec
Old Jul 9, 2010 | 05:54 PM
77777's Avatar
Default Re: sohc vtec swap
second star to the right and straight on till morning
seriously i have no ****ing idea
Old Jul 9, 2010 | 05:59 PM
mikej94civex's Avatar
if u are reffering to the vtec 'solenoid' it's on the firewall side of the distibutor fo i believe every d series vtec engine...the pic below is of a y8 motor, the red cirlce indicates the vtec solenoid
Old Jul 9, 2010 | 06:02 PM
for some reason i can't upload the pic, it's from google here's the link...
http://got-jdm.com/images/obd2%20vtec.bmp
u coulda easily searched this bro
Old Jul 9, 2010 | 06:08 PM
Kool_Aid's Avatar
I am trying to wire a sohc vtec into my '94 cx. what can ou tell me about that?
Old Jul 9, 2010 | 07:28 PM
77777's Avatar
its super easy, well i did it with a b series. depends on the ecu you run, i have no idea when it coms to the d series but i would think it cant be too far off what i did. you just ground a wire and run 2 into the proper spots in the ecu harness. with a 94 you probably need to add the pins.
searching is your friend, someone somewhere has put directions and pictures on the interweb for you to find.
obuhmyuh
30
Dec 21, 2007 12:10 PM
moosepoop21
16
Aug 13, 2006 03:04 PM
Yeehaw
Aug 18, 2004 10:16 PM
btcca4
Aug 12, 2004 12:45 AM
btcca4
Aug 12, 2004 12:40 AM
