99-00 SI rear LCA same as DX?
Old 09-14-2003, 11:23 PM
BI8B's Avatar
Default 99-00 SI rear LCA same as DX?
are they the same?
Old 09-14-2003, 11:35 PM
3RdT's Avatar
Default Re: 99-00 SI rear LCA same as DX? (BI8B)
i think tha dm is a lil skinnier.
Old 09-14-2003, 11:43 PM
BI8B's Avatar
Default Re: 99-00 SI rear LCA same as DX? (3RdT)
the SI is skinnier then the DX? or are you saying the SI is beefier?
Old 09-15-2003, 12:05 AM
Ehron's Avatar
I think the Si has a point to mount a rear anti-roll bar.
The Dx does not appear to (I know mine doesn't).
Old 09-15-2003, 01:24 AM
Banned
d0nkeyxPunch's Avatar
Default Re: 99-00 SI rear LCA same as DX? (Ehron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ehron &raquo;</TD></TR><TR><TD CLASS="quote">I think the Si has a point to mount a rear anti-roll bar.
what he said.
Old 09-15-2003, 01:50 AM
EddieHatchBlack's Avatar
96-00 Civic (Si, DX, EX, LX, CX, HX) all share the same Rear LCAs. They all have the supplied hole for a swaybar, but the SI is the only model that utilizes it.
If you wanted something "beefier," you should check these out.
Eddie.
Old 09-15-2003, 09:26 AM
B16b2b's Avatar
Default Re: 99-00 SI rear LCA same as DX? (Eddie HatchBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddie HatchBlack &raquo;</TD></TR><TR><TD CLASS="quote">96-00 Civic (Si, DX, EX, LX, CX, HX) all share the same Rear LCAs. They all have the supplied hole for a swaybar, but the SI is the only model that utilizes it.</TD></TR></TABLE>
yup. just use the si endlinks and mounting hardware, and you can mount either an si or gsr rear sway.
Old 07-09-2010, 03:08 PM
CaliforniaHonda's Avatar
Can you use GSR end links to mount it? I'm guessing you would need the SI brackets to mount the sway bar to the subframe as well. I just picked up a GSR rear sway bar at the pick n pull for $15 bucks and I'm looking to install it. Any help would be appreciated
Old 07-09-2010, 04:35 PM
318 Curves, 11 miles
Vindicator9000's Avatar
No, you can't use GSR endlinks on 99-00 Si control arms. You need 99-00 Si endlinks, but they will connect right up to the GSR sway.
The GSR endlinks are completely different, and don't mount to the same locations.
Old 07-09-2010, 07:47 PM
D Griff's Avatar
The LCAs are all the same. You need EM1 endlinks, like Vindicator said.
portfl0w
08-19-2007 02:29 PM
efracer
03-21-2005 02:45 PM
Blk00EJ8
03-02-2005 11:50 AM
grandmasterflex
01-17-2004 09:14 PM
Hayasa15
02-22-2002 07:29 PM
Quick Reply: 99-00 SI rear LCA same as DX?
