90 ef vtec?
Old Jul 9, 2010 | 04:04 PM
efkid88's Avatar
Default 90 ef vtec?
can i jus slap on a vtec head on my ef after doin mpfi
Old Jul 9, 2010 | 04:10 PM
SIef9's Avatar
Default Re: 90 ef vtec?
yes you can you will need other parts tho like p28 ecu,obd1 engine harness , obd0 to obd1 jumper, vtec wires ran n hooked on, obd1 dizzy, that vtec head slapped on most of all hahaha...
Old Jul 9, 2010 | 04:46 PM
efkid88's Avatar
the original engine harness wouldnt work even if its converted for mpfi?
and cnt i jus run the dizzy wires straight to the ecu?
Old Jul 9, 2010 | 04:48 PM
efkid88's Avatar
im jus tryn ta look for a cheap way lol
Old Jul 9, 2010 | 05:14 PM
EatMyVTEC :]'s Avatar
Do what SIef says. If you cut corners you will have a non working car.
Old Jul 9, 2010 | 05:15 PM
BiG ChOr!Zo's Avatar
http://www.lmgtfy.com/?q=mini+me+swap+write+up
http://www.lmgtfy.com/?q=mpfi+swap+angelfire
Old Jul 10, 2010 | 01:23 PM
efkid88's Avatar
ok kool helpfull info
Old Jul 10, 2010 | 03:48 PM
D16SiHatch's Avatar
so you don't get confused, sief9 is incorrect you do not need an obd1 engine harness. use your stock harness.
JDM_JNKY
Nov 6, 2012 07:52 AM
SingleCamin
Mar 5, 2009 11:57 PM
KRZRICAN
Nov 11, 2008 11:36 AM
TurboGoKart
18
Mar 30, 2007 11:11 PM
IntegraGuy16
Jun 24, 2006 05:50 AM
