JDM B16A distributor
Old Jul 9, 2010 | 06:35 AM
civicracer1997's Avatar
Default JDM B16A distributor
I have a OBD-0 JDM B16A in a '91 hf crx that I recently pulled and rebuilt. when I put it back together there was a screw left in the distributor that lodged itself in the gear that the crank angle sensor reads and sheared off 4 teeth. Now it is misfiring real bad and I have checked the timing like six times and everything lines up where its supposed to so I kno that this has to be my problem. My question is what are the distributor options for this motor? Do I have to use a JDM distributor or will any OBD-0 b-series distributor work?
Old Jul 9, 2010 | 07:19 AM
lunalink's Avatar
Default Re: JDM B16A distributor
no pic no info
Old Jul 9, 2010 | 07:51 AM
crx_si-r's Avatar
you can use the shaft w/matching gear from any 90-91 integra or 88-91 mpfi civic/crx. they are the same as long as they have the same number of teeth on the gear. you can use a 90-91 integra distributor but you will need to cut off one of the legs to make it clear the vtec solenoid. if you want an oem obd0 b16 distributor pm me i have one lying around that i no longer use.
Old Jul 9, 2010 | 09:08 PM
Thanks for the tip. I ended up taking the gear out of a f20 distributor that I had laying around and replacing the the broken one in my b16 distributor.
RanCRX
14
Mar 21, 2011 11:48 PM
solo303
Jan 29, 2006 12:52 PM
scheistermeister
Jan 22, 2006 08:01 PM
Big Bang
Nov 24, 2003 07:46 AM
Jared
Jul 12, 2001 06:00 PM
