Suspension & Brakes Theory, alignment, spring rates....
Issues installing HardRace rear-trailing arm bushings?
Old Jul 8, 2010 | 10:37 PM
LastDetail's Avatar
Default Issues installing HardRace rear-trailing arm bushings?
Hey guys, I have a 99 GSR and have been slowly upgrading the suspension components. It came time to replace the rear trailing arm bushings so I went ahead and picked up the HardRace hard-rubber trailing arm bushings that come with the sleeve and the perch already attached. I figured this would be a win-win with the combo of hard-rubber and not eurethane, and the lack of hassle of having to cut up the oem bushing in order to get the sleeve and the perch for the inserts.
Me and my friend used the specific rear-trailing arm bushing press tool to remove the oem assembly and it pressed out fine.
Then we lubed up the HardRace assembly and went to press it in. No matter what we tried the sleeve would not seat properly on the rear trailing arm. It kept pushing to the side and bent VERY easily. Once the sleeve got out of form it was impossible to work with.
Has anyone else experienced problems with the HardRace hard rubber rear trailing arm bushing? Is there another company that makes something comparable? What are my options at this point?
Old Jul 9, 2010 | 12:09 AM
Mashimaro's Avatar
Default Re: Issues installing HardRace rear-trailing arm bushings?
had no issues pressing my RTA bushings in (hardrace as well, complete kit). we used a press and a giant socket...worked on the first try, we didn't use lube though.
Old Jul 9, 2010 | 05:54 AM
phunhaus's Avatar
Pressing in a bushing is an art form. Get a new bushing and try again.
Old Jul 9, 2010 | 10:23 AM
xd69's Avatar
x2
You have no idea how many bushings and arms I messed up before i learned how to do it, lol
Old Jul 9, 2010 | 11:56 AM
LastDetail's Avatar
I see where you're coming from with that, however after the miserable failure of the hardrace product the stock bushing pressed in like butter.
beanbag
Sep 14, 2007 09:10 AM
SE7EN3S
Sep 16, 2005 09:57 AM
bigBOI_92DA9
Sep 12, 2005 11:28 PM
effects66
Jul 13, 2005 10:34 PM
Jays91DXhatch
Apr 27, 2005 08:19 PM
