Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
What kind of gas do you guys use on 7th gens
Old Jul 8, 2010 | 10:50 AM
Masho's Avatar
Default What kind of gas do you guys use on 7th gens
I've tried regular unleaded to plus, or v-power from shell, and sometimes the higher level gas at BP. and the thing is I do see a difference between them, the difference I see with my car is, is that my 7th gen seems to burn the unleaded gas ALOT faster then the higher octane gas, and by alot i mean alot. So Idk if it's worth the extra 10 - 20 cents to get the good gas or just stick to regular shell unleaded.
And I just tried Lucas for the first time, and it seems to add in a couple miles to the gallon. little difference.
Any opinions on that, and do higher octane gases really clean out your car as good as they say it does?
Old Jul 8, 2010 | 11:13 AM
TailZ's Avatar
Default Re: What kind of gas do you guys use on 7th gens
87
Old Jul 8, 2010 | 12:38 PM
toyomatt84's Avatar
Sanji
Your engine is tuned on non-premium 87 octane. To deviate from that octane can cause internal damage to the engine.
See your Owner's Manual before "testing" theories on necessary automotive fluids.
Old Jul 8, 2010 | 12:51 PM
Rob.C's Avatar
87 at shell only.
Old Jul 8, 2010 | 05:17 PM
theineffable's Avatar
there are a few theories and reasons as to why higher octane fuel "may" give you fuel economy.
here's one:
depending on your location, your local gas stations may mix in 10% ethanol into the fuel. higher octane fuels often won't contain any ethanol. anyways, ethanol has lower energy content than gasoline so in theory your fuel economy would drop when using fuel that has ethanol mixed in.
Old Jul 8, 2010 | 05:36 PM
It Wasn't Me's Avatar
No, fuel additives do.
And I use 87 octane.
Here.. read this. http://www.ftc.gov/bcp/edu/pubs/cons...tos/aut12.shtm
Old Jul 8, 2010 | 05:41 PM
Harlowe's Avatar
Function>Fashion
93
Old Jul 8, 2010 | 08:19 PM
sledchopper72's Avatar
Like rob c 87 and shell only.
Old Jul 8, 2010 | 11:52 PM
20-EM2-05's Avatar
Unless your car has some crazy F/I or NA build. You should only use 87, no point in adding an extra 10-15 cents per gallon for same results.
Use fuel additive if you wanna clean your motor.
Old Jul 9, 2010 | 12:51 AM
harms_is_back's Avatar
get v power from shell tecron from chevron you got some perfect vtec gas :D lol jk
Old Jul 11, 2010 | 06:21 AM
chewyv's Avatar
pm4nudes
BP gasoline.
Old Jul 11, 2010 | 04:08 PM
jdm em2's Avatar
87 anywhere because gas is gas.
Old Jul 11, 2010 | 04:33 PM
JDMLee's Avatar
87 chevron
Old Jul 11, 2010 | 05:22 PM
Igaly's Avatar
87 should be fine theres no need to put 93 octane on d17.....i do 87 on my civic i do 93 on my evo
Old Jul 11, 2010 | 06:23 PM
BYUFAN's Avatar
85 here in utah.
Old Jul 12, 2010 | 02:58 PM
20-EM2-05's Avatar
Damn you guys get 87-93? Lucky. Up here we only get 87-91.
Old Jul 12, 2010 | 04:17 PM
Igaly's Avatar
yea bro but its not cheap though the 93 is like $4 with some change a gallon :$
Old Jul 12, 2010 | 04:23 PM
Harlowe's Avatar
Function>Fashion
dams. its under $3 here
Old Jul 12, 2010 | 04:27 PM
20-EM2-05's Avatar
Damn that's alot. I remember when my bro went to Miami he took a picture of shell's gas price.
Reg=2.82
Plus=3.64
V-Power=3.65
I was like damn.
EM2_PLo's Avatar
How about fuel system cleaners? Are they necessary?
Old Jul 12, 2010 | 04:36 PM
Igaly's Avatar
Reg=2.82
Plus=3.64
V-Power=3.65
I was like damn.
yea, that was a long time ago thats why i use my em for my daily driver it gets filled up with $25 but my evo its close to $40 i bearly take that bitch out hahaha
bro honestly i do it every oil change, and it helps
Old Jul 12, 2010 | 04:42 PM
EM2_PLo's Avatar
O okay. Yeah I do the same thing. I put one every 4,000 miles and it's only about 7$. I was just wondering if it was necessary. Thanks man.
Old Jul 12, 2010 | 05:44 PM
XTCNRED's Avatar
regular.
Old Jul 14, 2010 | 09:48 PM
suds1485's Avatar
i was wondering the same thing. i have only put one tank full in my car. i used 93 in prelude though
Old Jul 14, 2010 | 10:23 PM
Alan-em2's Avatar
87 chevron or 76 and a lil bit of Dos XX
Farby100
Jul 3, 2016 02:13 AM
Veggie Man
Engine Management and Tuning
36
Oct 31, 2012 07:05 AM
lmike6453
Jun 29, 2008 09:14 PM
djdownfawl
13
Mar 23, 2008 07:57 PM
wizzards581
Feb 13, 2002 08:24 AM
