B16A to B20 non vtec. What is needed...
Old Jul 8, 2010 | 08:47 AM
Driven's Avatar
Default B16A to B20 non vtec. What is needed...
I have pretty awesome rod knock in my B16A... so, in hopes to repairing/replacing the engine, I'm thinking options, which is where the B20 came about.
So, was wondering what I needed to do to drop a B20 motor (head and block) into an OBD0 car that is wired for VTEC.
The main question I have is...
Can I use the B16A's distro on the B20 and call it a day?
Will a chipped P28 for a B16A work on the B20?
Eventually, I'll likely build a B20V, but for now... just wanna do it as cheaply as possible (hence, no VTEC).
Old Jul 8, 2010 | 09:00 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: B16A to B20 non vtec. What is needed...
For the Ecu get a PR4- any 90-91 Integra 5 speed...or if you go obdI, the 92-93 is also a PR4
use an LS dizzy, the B20 uses the same head as an LS....and they are cheap and easy to be had
Old Jul 8, 2010 | 09:02 AM
bigpudge's Avatar
dam i would just make it a b20vtech just get the vtec conversion from eagle and u will still run vtec thats my best bet
Old Jul 8, 2010 | 09:03 AM
bigpudge's Avatar
is the car the car obd1 converted?
Old Jul 9, 2010 | 03:21 PM
Driven's Avatar
thank you sir!
Old Jul 9, 2010 | 03:38 PM
DCRB's Avatar
like deetz said get an obd1 pr4, or have your p28 re chipped for the ls maps. just leave the vtec wiring tucked nicely away. if you're importing a jdm b20 you *should* be able to use the obd2 dizzy, although you'll have to re use your b16's intake manifold, and of corse the header
Old Jul 9, 2010 | 04:39 PM
Deetz's Avatar
Crazy Honda Guy
??? You telling him to use a vtec PR3 or P30 intake manifold on a B20 head? Won't work, not even close
If he buys a 99-01 B20, they already come with a low rise manifold. Here is a shot of the last one i had
immrtaltchnq
Oct 21, 2008 07:46 AM
cbabyby
Aug 22, 2006 02:48 PM
ekVtecPower
15
May 8, 2006 05:19 PM
JhorickJFL
Apr 18, 2004 01:33 AM
mafiosetto
Jan 25, 2002 11:24 AM
