1999 Honda Civic EX 2nd Cylinder has no compression...Zero
Old Jul 7, 2010 | 05:49 PM
Peaches3551's Avatar
Icon2 1999 Honda Civic EX 2nd Cylinder has no compression...Zero
i recently purchased a used 1999 Honda Civic EX and took it to an mechanic who said that he thinks it needs a new motor. He said that the 2nd cylinder has NO compression. I took it to the shop because like i said it was a used car i had just purchased and although it starts right up it frequently cuts off while driving, but will start back up immediately. Would this be cause to get a new engine? The engine has 184,000 miles on it.
Old Jul 7, 2010 | 06:13 PM
av911's Avatar
Default Re: 1999 Honda Civic EX 2nd Cylinder has no compression...Zero
Wrong forum.
Old Jul 7, 2010 | 06:35 PM
Vindicator9000's Avatar
318 Curves, 11 miles
If #2 really has no compression, then yes, it might be cause for a new engine. It means that something has failed badly on that cylinder.
He's probably saying that because used d16y8 engines (which is what is in your 99EX) are a dime a dozen. I see them in reasonable condition on hondamarketplace for a few hundred dollars.
As far as actual causes for your problem: It could be all kinds of things, none of which are good. Anything from a burned valve to a hole in the block, or a bent rod, broken piston, or similar. Generally though, major piston/rod/block problems will run worse than you're describing. I think it's likely more of a valvetrain thing, but there's no way to tell for sure without pulling the head off and looking at things, and possibly doing a leakdown test.
Long story short, it's likely cheaper in the long run to swap in a decent used engine than to chase down a diagnosis.
Old Jul 7, 2010 | 07:50 PM
jasonlindeke's Avatar
piston ring?
Old Jul 8, 2010 | 10:09 AM
Thank you so much!!!
Old Jul 8, 2010 | 11:41 AM
itsmejto's Avatar
If it were as serious as some say, it would be rattling or smoking badly.
My guess is a stuck or burned valve, burned would reduce the compression a lot but not to 0.
Stuck valve would be 0.
check em out first before taking it to pieces.
Old Jul 8, 2010 | 03:52 PM
thumper64's Avatar
If only we all had borescopes. Just stick a little camera inside the spark plug hole and look around.
You could make a tool using an old spark plug, an air fitting and some JB Weld or a welder. Connect the two and use it to blow air into the cylinder. Then you could turn the motor so both sets of valves are (or should be) closed and see where the air comes out.
Jack Murphy
Jun 27, 2018 03:11 AM
EK9ED
22
May 2, 2015 02:29 AM
meg1234
Jul 8, 2010 01:13 PM
