difference between d16y5 and d16y8???
Old Sep 15, 2002 | 05:24 AM
pbomers's Avatar
Default difference between d16y5 and d16y8???
what's the difference between the d16y5(hx engine) and the d16y8(ex engine)??? from what i can tell the exhaust manifold is different and the cam is(hx is more set for fuel economy), but what else besides that? or can i swap the ex cam over into the hx engine? i know the ecu is diff too.
thanks. Paul
Old Sep 15, 2002 | 08:07 AM
HXMan's Avatar
Default Re: difference between d16y5 and d16y8??? (TinyCRX)
...the VTEC lobe on the hx is actually "bigger"
Plus, the Hx head has roller rockers!
I am not sure if the Ex cam would work..but it may be worth a try.
A good Hx setup would be....ex intake mani and TB, good header, ex tranny....
If you switch ecus...you will have to rewire the primary o2 sensor on the hx.
[Modified by HXMan, 11:07 AM 9/15/2002]
Old Sep 16, 2002 | 06:08 AM
Spade's Avatar
NOTE: The EX cam uses three (3) intake lobes. Just like all the other VTEC engines. However, the HX is not a VTEC engine, it is a VTEC-E engine. Which uses only two (2) intake lobes. What the E stands for is efficiency. It is more efficient to (lighter as well) to just have two lobes, one larger than the other and to just have them lock together and follow the larger lobe. Just like VTEC only withouth the weight of another lobe and rocker arm. Let alone the four of them needed per cam. The 2001+ EX uses VTEC-E just like the 96-00 HX and 01+ HX.
The smaller 1.6L and 1.7L engines benefit from not having to turn the extra weight.
I wrote a thread a while ago on the specs of the HX vs EX cam. While it is documented that the HX cam has a higher lift on both the intake (.2mm)and the exhaust (.8mm) the duration is unknown. The only thing you do know is that the HX cam has a higher lift value.
Here is a picture of the roller rockers.
[Modified by Spade, 7:09 AM 9/16/2002]
Old Sep 16, 2002 | 08:36 AM
VTC_CiViC's Avatar
Default Re: difference between d16y5 and d16y8??? (Spade)
Although reasonable speculation would suggest the Y8 cam has a much longer duration than the Y5 to take advantage of the multiple cam profiles
Old Sep 16, 2002 | 11:02 AM
Spade's Avatar
Default Re: difference between d16y5 and d16y8??? (VTC_slow_CiViC)
I would think so as well.....plus, we don't know if the rocker ratio is the same.
The EX has a 1.6:1 on the intake and a 1.8:1 on the exhaust......does the HX have the same? I don't know and I traded it in before I found out. I do know that those roller rockers are a very smooth when it comes to friction on the valvetrain though.....just listening to it with the valve cover off right next to my EX was a WORLD of difference.
Old Aug 13, 2004 | 09:11 PM
Redline96LX's Avatar
* B A N N E D *
These roller rockers, can they be used in another engine, like a y8 or y7 valvetrain?
Old Aug 14, 2004 | 12:36 PM
Trixiem's Avatar
Default Re: difference between d16y5 and d16y8??? (Redline96LX)
spade i got a question for ya bro, would the HX run fine on an EX ecu? ii'm trying to run an uberdata setup but the only basemap i can find is the d16y8...
-kenny
Old Aug 14, 2004 | 12:38 PM
Quad-Damag's Avatar
Default Re: difference between d16y5 and d16y8??? (Trixiem)
i want to know whats the difference from the hx tranny and the ex tranny?
Old Aug 14, 2004 | 01:09 PM
dohcMONSTER's Avatar
Default Re: difference between d16y5 and d16y8??? (Quad-Damge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge &raquo;</TD></TR><TR><TD CLASS="quote">i want to know whats the difference from the hx tranny and the ex tranny?</TD></TR></TABLE>
ex has shorter gears
Spade
198
Jun 5, 2013 12:49 PM
BlueRex12
Oct 21, 2005 05:54 PM
mushu315
14
Mar 30, 2005 10:16 PM
EVIL Hx Coupe
Mar 16, 2002 11:45 AM
Slow&Furious
Jan 22, 2002 01:45 PM
