problem with gsr trans
first off i bought the car with bad shift linkage bushings. which didnt bother me none. second the transmission was leaking and it ****ed up the input shaft bearing. made second gear wind like as if it was a straight cut gear and fifth gear pop out when i let off the gas ONLY when i let off the gas. so i replaced the input shaft bearing which did its job because the old one had a alot of play with the shaft which was why it was winding and poping out. 2nd gear was rubbing against another gear. so the new input shaft bearing is in, put it all back togther in the car and now 2nd gear is being a bitch.. its HARD as **** to get in.will not go in while drivin but will go in while sitting still.. 5th gear dont pop out no more tho. can anybody tell me whats wrong.. sorry about the way i type.
did u ever figure it out??
i have a problem with third gear popin out after i let off the gas and also when driving i hear a chattering noise but it only happens in 1st 2nd and 3rd when i go over 2500 rpm...
corpsebesideme
Transmission & Drivetrain
Jan 8, 2018 01:40 PM
092eg6
Dec 2, 2009 01:33 PM
