what is this sensor...
i was hoping someone could help me identify this sensor...it's the one to the right of the TB and right under the PGM-FI..
Re: what is this sensor...
it is a vacuum dashpot.
quoted from
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/dashpots-2525374/
DESCRIPTION
It's function is to slow the closing of the throttle valve when it is suddenly closed during gear shifting or deceleration.
PURPOSE
This helps lower Carbon Monoxide (CO) emissions caused by sudden engine deceleration. Upon sudden deceleration, vacuum is applied to the Dashpot diaphragm and the diaphragm rod prevents the throttle valve from closing too quickly. Vacuum slowly bleeds from the Dashpot diaphragm allowing the throttle valve to close slowly.
quoted from
DESCRIPTION
PURPOSE
