Severe vibration and rear brakes dragging after rotor/pad/line install.
Old Jul 6, 2010 | 02:37 PM
mtny's Avatar
Default Severe vibration and rear brakes dragging after rotor/pad/line install.
The lowdown.
-new pads
-new rotors
-new lines
-new wheels/tires
-raised ride height 1"
-painted calipers
I went for a test drive yesterday and I had ungodly vibration over 40mph. Also the rears were dragging and smoking. I am going back out to the garage tonight to adjust the e-brake cable and make sure the rear pistons are lined up correctly. I'll update ASAP. Thoughts/ideas?
-Jeremy
Old Jul 6, 2010 | 02:38 PM
mtny's Avatar
Default Re: Severe vibration and rear brakes dragging after rotor/pad/line install.
Old Jul 6, 2010 | 02:40 PM
get RIGHT's Avatar
See if all the pistons are working properly, not sticking in any position.
Make sure your brake lines are not binding anywhere.
Make sure new wheels are in balance.
Had you went to Expo you probably would not be having this problem. <-----sorry I had too
Old Jul 6, 2010 | 02:48 PM
mtny's Avatar
Hahaha. <3
Going to gym then back to the garage.
Old Jul 6, 2010 | 05:40 PM
typer_696's Avatar
Make sure you bleed all the air out of the system. Rotate the tires around and see if the vibration changes. You may need to get them rebalances
Old Jul 6, 2010 | 07:15 PM
mtny's Avatar
They were just balanced. 0 miles on them. I adjusted the ebrake cable and fixed the rear pistons. I still have vibration. The front pass wheel and the rear driver wheel both wobble like they are warped. I swapped them around and they still wobble. It's not the wheels though, so I assume its the disc? Can a warped disc make it wobble even when its NOT under braking?
Old Jul 7, 2010 | 07:45 AM
teg97's Avatar
swap the discs around and see if it changes
Old Jul 7, 2010 | 09:09 AM
ericlee303's Avatar
I know you mentioned that you swapped the wheels but from my experience with countless instances of vibration on many cars it has always been the wheel/tire, never the rotors, bearings, or axles.
However, you mentioned that the vibration starts at low speeds which suggests it's not a tire balance issue. Maybe a bad new tire or a bad rim. Do you have winter wheels? If so, try them.
To eliminate the brake rotors, try your old rotors as well.
Old Jul 7, 2010 | 11:24 AM
nsxtasy's Avatar
H-T Order of Merit
If it were just a matter of tire balancing, the wheels wouldn't be dragging and smoking the way he described; it would ONLY be a vibration.
Old Jul 10, 2010 | 11:01 AM
2000FBPITR's Avatar
Pull the wheels off the rears and try and turn the spindle with ur hands. If they don't move (b/c of surface tension) there's a possibile issue with ur caliper (bad piston or ur ebrake cables need to be retensioned). If U take the caliper off and the problem persists U have a sticky wheel bearing (happened on my em1 rusted hubs). Also you can shake the hub back and forth and if it vibrates U probably have a bad wheel bearing.
90lsvcrxva
Suspension & Brakes
Jul 29, 2012 11:59 AM
Sam268
Jul 31, 2003 10:08 AM
HiRevn
Jun 23, 2003 11:00 AM
SonicGSR
Mar 31, 2003 05:55 PM
