would my spoon flywheel make my car do this?????????????????????
I got my car back and my R motor is just as good as it was just that now I put my SI ecu back in to run it till I get hondata in about a week my prob is that undre light thrautle like say 1200 rpms slowly reversing or moving forward as soon as I push in the Clutch the car sounds like it limps or wants to shut off but then it resets itself to 700rpm idle. It also does this sometimes when I just blip the throutle a little at a stop but below 1500 RPMs I think it is just my flywheel being so light the car has to catch up but is scares me casue I dont remember if it did it when i first had it car has beendown for 2 weeks. The car sounds like lumpy cams when it does this like it is going to die. IF it is not the flywheel than would a exhasut bottle neck cause it I have a real POS exhaust on ther till monday when I am getting my custom one made. I have JDM 4-1 smsp carsound then Greddy SP B pipe and stock SI axle back talk about a bottle neck
so if you have any ideas or place to start let me knwo
CHRIS
[Modified by underrated99si, 9:06 AM 9/15/2002]
CHRIS
prolly the ecu...
Yeah, I think your Si ECU is anticipating a flywheel weight quite a bit heavier than the one you're using. Add to that the normally expected problems you'd have running the Si ECU on an ITR.
I wish you had an alternative.
ATS*Mark
Dec 7, 2004 04:59 AM
Keyed ITR
Aug 20, 2002 08:57 PM
E46M3CB
Jan 25, 2002 07:25 AM
