right turn signal doesn't work when headlights are on
Old 07-06-2010, 07:09 AM
peglegpig's Avatar
Default right turn signal doesn't work when headlights are on
my turn signals used to work fine. now, for some reason, the right turn signal doesn't blink when my headlights are on.
both turn signals work fine when the headlights are off, but, when the headlights are on the right doesn't blink off & on.
also, i'm not sure if this is related but my passenger side window doesn't work anymore...
also, i did a search and found some related threads but really no good answers in those threads besides "you have the wrong bulbs in the turn signals". i'm pretty sure this isn't the problem as they used to work fine and i havn't changed the bulbs.
Old 07-08-2010, 04:48 AM
peglegpig's Avatar
Default Re: right turn signal doesn't work when headlights are on
bump.
Old 07-08-2010, 06:08 AM
318 Curves, 11 miles
Vindicator9000's Avatar
I think the right front bulb is weak. I had the same problem, and replacing the bulb fixed it. It could have to do with the extra heat from the parking light filament causing the turn signal filament to not work in conjunction. Or something like that. Either way, parking light filament and turn signal filament are the same bulb in front, and I think that's your problem.
What are the symptoms of the window? Does it just not work at all? Does it make noise like it's trying to work? Have you tried the switches on both sides? Are you sure you have the driver's side window lockout switched to on?
Frstyl838
Lighting
02-09-2009 01:07 PM
osofresh
10-18-2005 05:26 PM
mjrage
04-27-2003 03:34 PM
e-lauckd
08-20-2001 05:10 AM
Quick Reply: right turn signal doesn't work when headlights are on
