How do you remove rounded over nuts?
Old Sep 14, 2002 | 10:46 PM
Paste's Avatar
Loved
Default How do you remove rounded over nuts?
Its on the shock tower in the back, (the one inside the plastic cover in the hatch area)... EDIT-Does a nutbreaker work effectively? I tried it one time on something else and it messed up the bolt
[Modified by paste, 12:47 AM 9/15/2002]
Old Sep 14, 2002 | 11:48 PM
aeolus's Avatar
Default Re: How do you remove rounded over nuts? (paste)
harbor frieght sells a kit to remove stripped nuts and bolts.
Old Sep 15, 2002 | 12:23 AM
Westrock2000's Avatar
Default Re: How do you remove rounded over nuts? (aeolus)
hmm, maybe a socket and JB Weld, cost you a couple bucks though (considering the socket will be "disposable")
Old Sep 15, 2002 | 02:02 AM
ninesecrx's Avatar
Default Re: How do you remove rounded over nuts? (Westrock2000)
snap a pair of vise grips on them...that will break it loose.
Old Sep 15, 2002 | 05:50 AM
StyleTEG's Avatar
Default Re: How do you remove rounded over nuts? (ninesecrx)
oo, I had the same problem. Tried sooo many things to get it loose, including things people said here.
Socket + jb weld, vice grips, etc
What I got that eventually got it out with ease is this
http://www.sears.com/sr/product/summ...id=00952160000
Craftsman Bolt-Out™ Damaged Bolt/Nut Remover Set, got it from sears
Old Sep 15, 2002 | 07:48 AM
civic337's Avatar
Default Re: How do you remove rounded over nuts? (StyleTEG)
i got a set of those sockets from Matco. They work really good, and its a lot easier than trying to use vise grips and all the other stuff.
Old Sep 15, 2002 | 10:36 AM
Paste's Avatar
Loved
Default Re: How do you remove rounded over nuts? (civic337)
How much are the sockets? Isnt JB weld only around 10 dollars?
Old Sep 15, 2002 | 11:03 AM
yaya's Avatar
yeah if the vice grips dont work THIS WILL... try this be4 you buy all those tools and crap
get a dremmel with a thin cutting disk and put a nice deep slot accross the f***** up bolt...then unscrew it like it was a regular screw...with a flathead screwdriver of course
Old Sep 15, 2002 | 01:45 PM
Kamin's Avatar
Default Re: How do you remove rounded over nuts? (BrianP)
and if your not strong enough to loosen it by hand
get an impact driver (looks like a screw driver but you hit the end with a BFH and it turns it for you, had to use one on my brake disk screws)
Old Sep 15, 2002 | 04:45 PM
the DR.'s Avatar
Default Re: How do you remove rounded over nuts? (KAMiN)
go buy a cheap 12pt socket from kragen or something, make sure its a little smaller than the bolt size, hammer if down on the stripped bolt, then take the bolt off.
Old Sep 15, 2002 | 07:40 PM
TimoneX's Avatar
New User
Default Re: How do you remove rounded over nuts? (CIVICtypeS)
Use a nutbreaker. It'll either cut it enough so it breaks, or you can turn the nutbreaker...and therefore the nut.
Old Sep 15, 2002 | 09:55 PM
aeolus's Avatar
Looks almost the same as the harbor freight kit.the concept is the same.Probably cheaper too.
Old Sep 15, 2002 | 10:11 PM
Paste's Avatar
Loved
Yeah i thought about it, OT-I dont think we have kragen's around AZ...
Old Sep 16, 2002 | 08:22 AM
StyleTEG's Avatar
Yeah, I tried both those ideas. (I had the same stripped nut that you have).
The hammering on a smaller socket just messed it up more, and the nutsplitter had clearance problems.
What I suggested before will work.
untitled23
Apr 29, 2010 02:36 PM
Chan_man
Sep 30, 2008 12:23 AM
16yroldekownr
Jun 17, 2008 06:09 PM
AdReNaLiN
Apr 2, 2006 01:57 AM
mars
May 7, 2005 08:05 AM
