b18a1 ground points
Old Jul 4, 2010 | 09:16 PM
b18crx823's Avatar
Default b18a1 ground points
Im almost done swapping my b18 into my crx shell but im not sure where i need to have the grounds coming from. Any help would be appreciated.
Old Jul 4, 2010 | 09:29 PM
D16SiHatch's Avatar
Default Re: b18a1 ground points
-thermostat to main engine harness
-valve cover to front core support (or near firewall if you prefer)
-transmission to lower subframe near battery
-battery negative to chassis and/or engine block
Old Jul 4, 2010 | 09:33 PM
Duane_in_Japan's Avatar
Some guys dont like em, but how about putting an Earthing Kit on it, that will cure all your woes. Stay away from any water flow areas, near the thermostat housing, water necks, radiator mounts, heater hose areas.
Most important, battery to engine or tranny, chassis to engine to tranny to chassis, bond the exhaust to chassis back there somewhere, keep grounds in plain sight if you can and away from the battery area where acid fumes will cause corrosion in the not too far future.
Natural grounds like Alternator to bracket to engine, AC compressor to bracket to engine, no harm in adding redundant grounds to things like that. Dont put a 14 gauge wire spliced into an 18 gauge to ground. Now back to the radiator, bond it to the frame up there but not to anything else. Clean the paint from your ground points and treat them to keep them from corroding later.
jsoccer
Aug 18, 2010 01:18 PM
88efZ6
Nov 7, 2008 08:30 PM
infamouskillas
Apr 21, 2008 03:20 PM
mskibbz-T
Apr 27, 2004 03:12 PM
wannab20hatch
Oct 12, 2002 10:15 AM
