engine grounds??
Old Apr 20, 2008 | 07:52 PM
infamouskillas's Avatar
Default engine grounds??
hey guys
i got that NRG Engine Ground Kit...
it came with:
a new negative terminal:
and 7 engine ground wires...
i only replaced 2 of the engine ground wires and used 1 for the battery terminal
that means i have 4 left and i don't know where the other engine grounds are as bad as that sounds... can anyone help me out??
i'm gonna search it right now...just remembered...
but thanks guys
Old Apr 20, 2008 | 07:57 PM
Default Re: engine grounds?? (infamouskillas)
yeah so i searched "engine grounds" in the search link and i couldn't find anything that would really help...
i forgot to let you know as to what grounds i replaced...
- negative battery terminal ground
- valve cover ground
- tranny ground (by the intake)
Old Apr 20, 2008 | 08:09 PM
NUISANCE's Avatar
I put one behind the head below where the PS bracket would connect. It's a big threaded hole that is right below that spot.
Old Apr 20, 2008 | 08:10 PM
A's 94 GSR's Avatar
BG-33P
is the nrg kit specifically for integra's or universal? if its universal they probably threw in more then you need because its a universal kit, you know?
Old Apr 20, 2008 | 08:14 PM
Default Re: engine grounds?? (A's 94 GSR)
yeah A i'm pretty sure it is universal...just thought i would be using more than three...thats y i might ask and make myself sound like a noob..
nuisance:
I don't know exactly where you're talking about...in case you haven't heard, i am a noob and still learning about my gsr...where is the PS bracket??
is there a way you can find a picture and circle the area it would be in??
visuals help a lot...
thanks again and sorry for giving you guys a hard time
Old Apr 21, 2008 | 08:51 AM
trips customs's Avatar
Yeah its a universal grounding kit. Your not going to hurt anything by adding extra grounds, so just try it. Remove a bolt, add ground, put bolt back and your done.
Old Apr 21, 2008 | 11:06 AM
albertoG87's Avatar
Default Re: (trips customs)
The PS bracket is right next to the header on the right side. it goes on the top four threaded holes not to be confused with the bottom four that are for the ac bracket. hope that helps you
Old Apr 21, 2008 | 03:20 PM
Default Re: (albertoG87)
aight thanks it helps a lot...
can't do it right now tho cuz my car is in the body shop...need repairs
thanks again guess....greatly appreciated!
davejj40
Sep 9, 2004 11:40 AM
H22CL
Jan 15, 2004 04:06 PM
steve_s
Feb 21, 2003 08:59 PM
Erik_Pb_Foot
Mar 8, 2002 04:59 PM
S13Koop
Aug 12, 2001 04:21 PM
